Old 10-03-2004, 03:00 PM
Bluegem Bluegem is offline
Transmission
I have a slight grinding in third gear - do i need to get a new transmission soon or is it a clutch problem? someone told me that i need a synchronizer, whatever that is.
Old 10-03-2004, 03:25 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: Transmission
yup, sounds like your synchro is going out. Just be easy on it when you shift into third. You could rebuild the tranny, but that is major $$$. When you really start to have problems, it's better and more cost efficient, in most cases, to just replace it with a used one.
Empty Pockets Racing Member #1
Old 10-03-2004, 03:41 PM
rushb18 rushb18 is offline
Re: Transmission
This could help that grind out..Have the tranny fluid changed mos tof the times you get little metal shavings in between the snycros and it causes that grind try that if not just by a new tranny and keep that one as a back up rebuild it or whatever..Later..
