Old 10-03-2004, 01:32 PM
amistad6 amistad6 is offline
91 Accord Drivers Side Wheel "Metalic Clank" on Bumps
91 Accord Stock.
When I'm driving down the road and hit a bump with the left (drivers side) front wheel I hear a metallic clank. I don't hear it on the other wheel(passenger). I can replicate this sound almost all the time by driving over a bump (pothole, patch of uneven pavement, roadkill).
I have noticed that when I apply my brake and run over similiar obstacles I cannot hear the metaliic clank at all (100% of the time). I tried this uphill downhill, slow and fast, with both the brake and accelerator applied.
I did have a place quickly inspect that wheel and they observed that the bearing on this wheel was worn. The guy heard the clank (on a test drive) and said that, that shouldn't be a cause of the clank.
I can't tell anything else performance wise, I looked under the car and nothing seems to be "loose". The car drives normal.
What can this be.. I'm thinking something brake related since it doesn't happen when the brake is applied. The clank is pretty significant. Like two pieces of thin metal are being banged together.
Old 10-03-2004, 06:03 PM
DJ Brady DJ Brady is offline
Send a message via AIM to DJ Brady Send a message via Yahoo to DJ Brady
Re: 91 Accord Drivers Side Wheel "Metalic Clank" on Bumps
any chance your brake caliper is loose?
Old 10-04-2004, 10:37 AM
excoupe23 excoupe23 is offline
check the stabilizer bar bushings at the lower control arm. I noticed one of mine was gone and that's what made a metallic noise everytime I hit a bump. -Definetly check that out.
Old 10-04-2004, 01:03 PM
ProMan ProMan is offline
Re: Re: 91 Accord Drivers Side Wheel
Should be it. Also, if the rubber pads are cracked or broken, you should replace them.
