Old 10-03-2004, 01:30 PM
matt 93 eclipse matt 93 eclipse is offline
Exclamation Transmission swap
Hey Guys ,
I am starting to do a JDM engine swap on a 93 eclipse from a 1.8 to a 2.0. I need to know if the manual Transmissions are the same ? Or if I need to buy a new one . First time doing a swap on a mitsubishi done them before on Nissans.. Thanks.......
Old 10-03-2004, 01:42 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: Transmission swap
yes the manual trans is the same on all 1st gen fwd's. you will need to change the engine wiring harness and ecu. probably motor mounts too
just wondering why you want to do a jdm swap?
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 10-03-2004, 02:29 PM
Thanks Its My brothers car The 1.8 that is in it has a hole in the block and he was wanting to put the JDM 2.O in it.How much does the ECU and wiring harness run for this car. The guy who I buy the engines through said the ECU and stuff should work I dont know Im just trying to find out what I need to have ready. I have a nissan NX 2000 and I did A JDM engine swap on it. Runs Great... Thanks For Your Help.
Old 10-03-2004, 04:09 PM
the ecu and wiring are definately not compatible. im assuming that you want the turbo 2.0. check dsmtrader. you're basicly going to need a parts car to rip apart since the wiring comes in through the firewall to the ecu thats behind the radio. from a junkyard a ecu is between 50-100 bucks so i dont know how much for the whole thing. if you want a 2.0 nt i can sell you the whole car.
-1stGenRocks-
