Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 10-03-2004, 12:39 PM
wadigo wadigo is offline
Question fast idle
I have a 325 is 1987. when the a/c is on and the car warms up the revs go up to 21-2500, it remain there for a while and then it drops down to 900, and it goes back to the same cycle. It only happens when the a/c is on.
Changed the idle valve. Still same problem. Help!!!!!!!!!!!!!!!!!!! what else could it be short of experimenting $$$$$ with something else
Old 10-03-2004, 08:27 PM
KC Ron Carter KC Ron Carter is offline
Hmm,
OK, you do know Sam?
He is the KING of idle.
http://www.mesaperformance.com/faqs/idle.html
But as a real deal shortcut, consider adding a restrictor whith a 1/4 inch hole up stream of the idle air valve, thus restricting the max air it will flow.
I use a rubber washer to restrict mine.
Later,
Old 10-06-2004, 01:38 PM
Chspyder Chspyder is offline
Re: fast idle
I have had this happen a couple of times on my 88 325i it seems to come and go by it self (AC or no AC) Wierd, The IAC makes a ton of flucuation but the Haynes test checks out ok.
Re: fast idle
Also have any pics of the fix?
