Old 10-03-2004, 12:36 PM
Tikiman's Avatar
Tikiman Tikiman is offline
ProgRess: '69 Camaro Z28 (Street machine)
I've been working on this 1/25 scale Revell Monogram kit about a week now. I got a bit tired of making kits that look like the ones on the box (and other peoples) so i decided to do something a bit different. It is the first time i have done this sort of thing so progress might be a bit slow. Also because of this i would really appreciate advice and comments from you guys. Thanks.
First i got some different shapes of styrene and created a kind of framework.
Then i started to build up with some filler.
This is the kind of shape i was thinking of using for the side but i'm not sure yet.
Also i have decided to use these headlights instead of the custom Z28 ones. I just think they look better.
I might do something with the bonnet. Dunno yet.
Old 10-03-2004, 01:01 PM
flying finn's Avatar
flying finn flying finn is offline
Re: ProgRess: '69 Camaro Z28
This looks cool! Little sanding and filling left to do but donīt give up!
"Rat rod – Usually a hot rod with an excessive amount of patina and some less than ideal engineering principles"
Old 10-03-2004, 01:14 PM
GvEman's Avatar
GvEman GvEman is offline
looks impressive! a bit diferent but i like it!
you should go with just a net in the front instead of that molded grill.. and then just put lights behind. that would look awesome.
but that is my opinion.
keep it up
Best Regards
Anton
Old 10-03-2004, 01:21 PM
Tikiman's Avatar
Yeah i was thinking of something like myself, but i wanted to save that for my next project. I was going to make a grill like the existing one but make it go all the way across. Making it out of strips of styrene.
Old 10-03-2004, 02:34 PM
MidMazar's Avatar
MidMazar MidMazar is offline
the vents in the rear look great, creative!!!
In Progress
Old 10-03-2004, 02:37 PM
americanmuscleman americanmuscleman is offline
Send a message via AIM to americanmuscleman
yes my favorite car. i like to see them different and urs looks cool. it reminds me of being modified the way eleanor was for gone in 60
Old 10-03-2004, 02:38 PM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
its different, but nice.
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 10-03-2004, 05:42 PM
Tikiman's Avatar
Thanks for the comments. the colour by the way is going to be Tamiya dark metallic blue with a light yellow interior.
Old 10-05-2004, 02:51 PM
Tikiman's Avatar
A bit of progress. It is going very slow as it is all quite experimental for me. This may also be reflected in the simplistic design of the body kit.
basically i have done alot of smoothing and shaping, but still plenty more to do and put some kak on the back which will be shaped into a rear bumper.
Old 10-05-2004, 02:56 PM
mike united's Avatar
mike united mike united is offline
Looking good Matt, sure doesnt look like its your first putty job !!!
Mike
Old 10-05-2004, 02:57 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
look's good so far, I've never seen an older camaro with a body kit before.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 10-05-2004, 03:14 PM
Tikiman's Avatar
Re: Re: ProgRess: '69 Camaro Z28
Thanks Mike. Believe me, it's getting me plenty frustrated. To top it off i think i might have put a bit too much filler on which may or may not have caused the body to warp a little. Anyway i'm sure i'll figure it out.
That's a bit of the reason i am doing it. I have seen a few people have done the same car but looking like on the box, so i decided to do something different and maybe learn some skills into the bargain.
When i have smoothed the rear out i thought that i would spray on some primer or matt paint to get a better idea of exactly where i need to work on more.
Old 10-05-2004, 05:56 PM
primera man's Avatar
"P-Man"
Looks very different.
At first glance i thought...WTF have you done to a classic car.
But after taking a closer look its growing on me and i'm starting to like the different lines you are bringing out.
View All My Models Here.
Old 10-05-2004, 06:22 PM
Tikiman's Avatar
Thanks PMan. I'm trying to keep as much of what makes it cool in the first place but more to my exact taste. I don't suppose i would do the same if i had a real one, but it is just a model so what the hey!? I just thought it could do with beefing-up a bit.
I've ordered the SPOCOM set from HLJ, so i might be using the seat/s and wing. Not sure yet, not untill i get my hands on it. I might even do it with just one seat and throw in the NOS bottles or i can put them where the back seats should be.
Old 10-05-2004, 06:40 PM
will69camaro will69camaro is offline
Send a message via AIM to will69camaro
there is a body kit out for first gen camaro's. A guy by the name of Tyler Beaugard who runs www.t56kit.com (place to buy stuff to put a new 6 speed in an old camaro) is building a 68 camaro with a C5 vette driveline (rear transmission and all) and it has a body kit. I've been having problems finding pics but it's green and they're out there so look it up it's "project 50/50"
William
if i can find the pics i'll post links later on
