Go Back   Automotive Forums Car Chat > Mitsubishi > Mirage
Old 10-03-2004, 12:21 PM
NellyzNell NellyzNell is offline
Send a message via AIM to NellyzNell
93 es
My cars dome light does not work, the radio resets itself everytime the car is turned off and my car has to be running in order for the automatic seat belts to work. Can anyone help me.
Old 10-27-2004, 02:43 PM
jjautomotive jjautomotive is offline
same problem.....I have... since I bought the car.... it had an aftermarket stereo..... i believe it may be the wiring behind the stereo...... also you probably have a blown fuse 10amp..... if i figure this out I'll let you know if you figure it let me know.... good luck
Old 10-27-2004, 08:48 PM
Re: 93 es
Ok I will
Old 11-08-2004, 12:00 PM
DSM-Mark's Avatar
DSM-Mark DSM-Mark is offline
Re: 93 es
Do you reallize that to turn the dome light on, you slide the dome light lens over? The light cover acts as a switch. There are three positions.
1) On all the time
2) On when a door is open
3) Off all the time
When I first bought my car, I thought the dome light was dead too. I suspected a burnt out bulb. When I tried to get the cover off, low and behold, I accidently moved it over and the light came on!
If you did know that, then I would suggest either a bulb or a fuse needs to be replaced.
I work slowly!
Old 11-08-2004, 03:02 PM
Re: 93 es
Yes I knew that
Old 11-24-2004, 09:26 PM
Re: Re: 93 es
I fixed my car. The problem was that one of the fuses were broken and that screwed up everything. So check all the fuses and see if any need to be replaced.
