Go Back   Automotive Forums Car Chat > Honda > Integra
Old 10-03-2004, 10:09 AM
Importbuyer Importbuyer is offline
Send a message via Yahoo to Importbuyer
Spun Bearing?WHAT TO DO???
someone mentioned a spun bearing,well i fear thats my current problem, also probably caused by over revving...WHAT ARE MY OPTIONS??? I was in a rush for a new car,and bought a car turned out to be a beater!
Seems like most of the S*** in the car is messed up,and im hoping to find a car in better condition,with more options,maybe a blown motor or whatever,and build a decent motor,but in the meantime,what do i do?the sound is at all rpms,and is relatively new,i was told if i do it quick enough,i may be able to just drop the oil pan,and pop out the old and put in new(rod bearings i assume),should i buy same size or oversized?and if oversized,how much?sound is only a few weeks old...
i dont want to rebuild this motor because im unsure of what was done to it,and id like to buy more time with this car to find a better integra,one with AC,maybe some power windows and locks?
If anyone has any suggestions of a way to fix/buy me some time,id apreciate it!!!
My last car was a toyota paseo,it was fun,but it got a spun bearing within 4 or 5 months...my luck cant be that bad!!!
Love integras.wont go back,please help me!
Old 10-03-2004, 02:54 PM
integralover's Avatar
integralover integralover is offline
that same thing happened to me back in june. i took my car to everyone and they said it was my valves tapping. so i replaced the head and the sound was still there. and they kept telling me that it was my valves hitting a piston. finally one guy told me that i probably spun a bearing. well sure enough that day my engine went. from what my friend said it could have been repalced by dropping that oil pan and fixing it before but, by then it was too late. so i had to get another engine. i ahd a racing chip in at the time and was reving it to 8k rpm's. your best bet is to get this fixed as soon as possible. the longer it goes the more of a chance that it will be non repalceable. sorry to hear that though. but keep in mind you might need another engine. and the engine i got was only $700. and i put it in myself so i saved alot more money.
93 teg LS
B20B
ACT Performance Flywheel
AEM CAI
DC Sports Stainless Steel Header
G4 High Flow Cat
GReddy MX Cat Back Exhaust
Skunk2 Racing Chip
Lots of interior goodies
Old 10-04-2004, 01:21 AM
well then...
i guess the question then is do i go with an oversized bearing,and if so,by how much?Anyone have a certain brand they recomend?or should i shuck out the big bucks and go with an oem honda one?like the last guy said,i have to do this asap,so someone let me know quick,please...
Old 10-04-2004, 02:24 AM
i was told that it would not be a good idea to go with an oversized one. try to take it apart to see if it has worn into the block. if not get an oem bearing. if it has your block will need to be machined and in that case you might want another block or engine.
93 teg LS
B20B
AEM CAI
G4 High Flow Cat
Skunk2 Racing Chip
Old 10-04-2004, 08:01 AM
almxdupintegra almxdupintegra is offline
Re: Spun Bearing?WHAT TO DO???
How could you tell you spun a bearing?
FRIENDS DON'T LET FRIENDS DRIVE STOCK
Old 10-04-2004, 08:56 AM
it actually sounds as if your valves are tapping but, if you take one of those stethescopes that mechanics use or if your have a small wooden bat you take one end, stick it on the engine and place your ear on the other. now place it on top of the valve cover and move it around the valve cover. the sound should get louder the closer you get to what is causing the noise. now with a spun bearing you move it around the engine, and it kinda sounds like it is coming from the front of the engine(cam side) where the timing belt is. sounds as if it is all over the front of the engine. that is what was perplexing some of the mechanics that i talked to. they could hear the sound all over the engine and could not pin point it. when the valves tap you will be able to pin point which valve it is that is doing the tapping.
93 teg LS
B20B
AEM CAI
G4 High Flow Cat
Skunk2 Racing Chip
Old 10-04-2004, 08:01 PM
boosted k20's Avatar
boosted k20 boosted k20 is offline
what rpms did u take ur car up too? u could have also bent a rod. that makes a ticking noise too.
if u think u spun a bearing, drop the oil pan and pull out the rod caps. change that bearing before it messes up ur crank. if it did already ur gonna have to drop the whole crank out to get it resurfaced.
www.MEDIUMRACING.com
Old 10-05-2004, 12:08 AM
I took it up to 5 maybe 6k rpms...i dont think ive gone any higher...didnt notice any problems until these last hurricanes(in daytona,florida),computer got a lil damp,and it ran boggy for a day...and the clutch safety button got messed up,is there a chance somehow this could have helped?just dropped car off at mechanics,and hope to have some answers soon...
