Old 10-02-2004, 10:27 PM
aznstealthsnake aznstealthsnake is offline
1997 cav factory radio......
I just bought a 1997 cav and i want to put an aftermarket radio. I searched the forums and i heard it inflates the airbag or certain things dont work anymore. IS this true about the 1997?. And the i need a harness and wires?
Old 10-02-2004, 10:52 PM
KJRich's Avatar
KJRich KJRich is offline
Send a message via AIM to KJRich Send a message via Yahoo to KJRich
Re: 1997 cav factory radio......
Rumors apply to the 2000 and newer, I believe. You should be fine. The only thing that really happens on the newer cars is you lose your key-in or headlight-on chime.
1999 Chevy Venture LS Extended 3.4 V6 Intake Gaskets Replaced
2003 Cavalier LS Sport Coupe, 2.2 Eco, 5 speed Getrag, all black
Old 10-03-2004, 12:16 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
wire harness and radio antenna adaptor, soderer, sodering wire, black electric tape, the knowledge on how to take your dash apart, its in the haynes repair manual, or if you buy a deck from crutchfeild.com they send directions, some good amount of time and a cold beer or ice tea..w/e you get the idea...its really easy.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 10-03-2004, 03:46 PM
Mangoamerican Mangoamerican is offline
Send a message via ICQ to Mangoamerican Send a message via Yahoo to Mangoamerican
the hardest part of replacing the stock radio is taking that DAMN dash apart.. i hate that! i cut the plastic peice that holds in the radio, bodo then painted it.. probually 10 times the amoundt of effort.. but shit
Old 01-18-2009, 10:09 PM
chevygirl03's Avatar
chevygirl03 chevygirl03 is offline
to replace your stereo you will either need to get the plugs from circuit city that match or just splice the wires this I found out the hard way. you wont hurt your airbag system or lose any chimes if you properly wire everything. this is wiring colors for the splicing.
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
after you connect all of your speaker and power wires you will wonder what to do with your 2 dimmer wires. and the green wire with the white stripe (not the one that goes to the speaker) the brown and grey dinner wires will be connected together and to your new stereo dimmer wire (usually white) and the green wire with white stripe do not connect to anything and do not ground. just tape off by itself. if you arent confident take it to best but and installation is $50 they do everything for you.
Old 01-19-2009, 12:08 PM
omg thanks! But....this post is late by almost 5 years.
