push button 4x4
my buttons quit working will not switch into four high or low any suggestions
Re: push button 4x4
Do the lights come on the switches?
Re: Re: push button 4x4
no but when i first start they all do and the 4x4 ones shine white they used to be orangeish
Re: push button 4x4
Sounds like the vacuum actuator on the transfer case is bad.
ok any help on how to change this and is it expensive? thanks
Re: push button 4x4
If you have one, it is located on the driver's side of the xfer case. It will be identified with 3 vacuum hoses on top. It will cost about $25 and you will need a 7/8" deep well socket or a short wrench.
Re: push button 4x4
I suggest you pick up a chilton's repair manual.
Cost will be about 20-30 if that is the actual problem. |
