Old 10-02-2004, 09:14 PM
CobraR2000's Avatar
CobraR2000 CobraR2000 is offline
Send a message via AIM to CobraR2000
Thumbs down Oil Pressure
Well, I have a 96 Cobra and its become a concern of mine, the oil pressure guage is now on the edge of normal and in its way to where I'm going to be introuble soon. I'd be pissed if I blow my engine or some internals get screwed up. My friend said his friend is a machanic and could do some checks on the engine. It could be a clog, oil filter, or just the guage is screwed up. Do you have any advice on what to do or what else it could be or most likely is ?
1996 SVT Cobra Coupe
320 HP@ 5800RPM
DOHC 32 valve
BBK Cold Air Kit w/ 87mm MAF, March UD Pullies
My Snake
Old 10-02-2004, 10:34 PM
silverstangs's Avatar
silverstangs silverstangs is offline
Send a message via AIM to silverstangs
The old pumps that comes with our mustangs have some fragil internal parts. But, it does not loose pressure slowly. When it breaks, it's broke. I would suggest you replace the sensor, and flush your engine a few times. Also you ARE using 5w-20 right?..........
I'm using the motorcraft oil filter, they do a better job than the rest of them out there. I will be converting to a By-Pass oil system soon thou. That might be a option for you.
My ride at my site Silverstangs.
Old 10-03-2004, 05:32 PM
burly94gt burly94gt is offline
Re: Oil Pressure
my 94gt has the same prob...ever since ive had it the oil gauge has been very low but still in the normal margin. i dont know what the prob is??
God said RWD, and all the little torque lovers of the world said, AMEN!!
Old 10-03-2004, 08:24 PM
CobraR2000's Avatar
Re: Oil Pressure
Well I think I'm going to purchase a oil filter, my friend showed me a site and basically every factor said get a new oil filter. Hopefully that will help.
burly mines the same just on high its annoying lol
320 HP@ 5800RPM
DOHC 32 valve
My Snake
Old 10-04-2004, 02:49 PM
Re: Oil Pressure
i just changed my oil 2days ago and still no change?? wierd
Old 10-06-2004, 10:08 PM
CobraR2000's Avatar
Re: Oil Pressure
i noticed with the new cold air kit i installed the oil pressure moved slightly down, which is a good thing
320 HP@ 5800RPM
DOHC 32 valve
My Snake
Old 10-07-2004, 09:08 AM
blue_GT_89 blue_GT_89 is offline
I use Wix oil filters they have a foam filter instead of paper like the motorcraft uses you might want to run some 10w-40 in it, how many miles are on it
Old 10-07-2004, 06:01 PM
CobraR2000's Avatar
Re: Oil Pressure
its low, for at least a 96 cobra, it has 61,000 miles on it
320 HP@ 5800RPM
DOHC 32 valve
My Snake
