Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 10-02-2004, 06:41 PM
dbailey62 dbailey62 is offline
94 Jimmy Vacuum problems
I've got multiple systems acting up and think the vacuum system must be fried.
Criuse control, won't set at all.
A/C / Heat. Dampers won't adjust. All air blows to floor and Air intake closed.
Power brakes. If engine is at idle, power brakes aren't power.
Any Ideas where to look for the problem. Is there a vacuum tank / pump to have vacuum when the engine is at idle or off?
Thanks
Old 10-22-2004, 08:02 PM
rabbit2475 rabbit2475 is offline
Send a message via Yahoo to rabbit2475
Re: 94 Jimmy Vacuum problems
you can look on the back of the plennum(intake) there is were the vacumm line hooks up..I similar problems and reconnected and it worked great
Old 10-23-2004, 04:05 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
There are vacuum lines going from the rear of the intake to the brake booster and to a T where is connects to a vacuum ball in the drivers corner.
Check all the hoses for cracks etc....
You need to actually go out there and look bro, we can't tell you whether they are broken or not.
