Old 10-02-2004, 04:50 PM
EclipseBabe95 EclipseBabe95 is offline
temp gauge
hey - my stock temp gauge has stopped working and i know its the gauge and not the sender cause i took the gauge out and put voltage to the terminals and the needle didnt move. so what do you suggest i do? should i get a gauge pod for the a-pillar and put in an aftermarket gauge, or should i look around for another stock gauge to replace the original?
if the answer is an aftermarket one on the a-pillar, what temperature range does the 420a run at? because obviously there's numbers on the gauge not red and white lines. thanks sooooooo much!!!!
-a
BUY MY CAR!!!! www.clarkson.edu/~desjarrf/keldra.htm
very reasonable price....
[email protected]
Potsdam, NY
2001 Yamaha YZF600R
95 Eclipse GS
Old 10-02-2004, 07:03 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: temp gauge
i would just get a junkyard gauge from another rs/gs. btw putting voltage to the terminals might not be the best idea since they usually run on pretty low voltage and it would be easy to burn up the gauge
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 10-03-2004, 09:52 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: temp gauge
Guage failure should be very very low, I would certainly expect the sender to go first. But a "real" coolant guage is always a good mod anyway if you wanted to go that route. Same with the oil pressure guage. The "lines" on the stock guage are useless. For 99% of cars normal coolant temps are right around 190-200 degrees. It will vary though, and up to 220 or so I wouldnt panic. Mine gets that high and sometimes more in the summer because of the FMIC. Another stock guage is usually cheapest option though. Might want to replace the sender first and hope you didnt put too much voltage to the guage.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 10-03-2004, 10:12 AM
k thanks guys, its a big help
if i cant find a replacement stock gauge, is installing an a-pilliar pod and routing wires for an aftermarket gauge hard? thanks a lot
-a
[email protected]
Potsdam, NY
2001 Yamaha YZF600R
95 Eclipse GS
Old 10-03-2004, 02:13 PM
Re: temp gauge
apiller pod and routing wires is easy. check vince(boostedspyder) cardomain page in his sig. he has a good tutorial with pics from when he did his
-1stGenRocks-
Old 10-04-2004, 07:37 PM
johnny2quick johnny2quick is offline
Re: temp gauge
-a
if you want i can see if the '97 rs i'm parting out has this stock guage. let me know. i'm taking pics tomorrow. i'll get on of this
