Old 10-02-2004, 03:42 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Boring out a dohc zc.....
Anyone know how far a zc block can be bored? Its possible that i might do a lil somethin to one of my engines. So if anyone knows, give me some info.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 10-03-2004, 01:33 AM
91civicDXdude's Avatar
Re: Boring out a dohc zc.....
if you can bore a b series 4mm on stock sleeves, i'd say you could probably bore a D16 (ZC) to 77mm atleast, I havent heard of anybody going over 79mm on a d series
Old 10-03-2004, 07:37 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
who told you that you can bore stock sleeves to 85mm from 81mm ? because they told you wrong, it is not recommended to bore stock sleeves more then .5mm so 81.5mm on b series. i would assume its around the same with d series.
if you want to go bigger, get it sleeved then you can go alot bigger bore
Team Lonely Drivers
Old 10-03-2004, 08:56 AM
Santas90Si Santas90Si is offline
Registered User
Send a message via ICQ to Santas90Si Send a message via AIM to Santas90Si Send a message via Yahoo to Santas90Si
".5mm so 81.5mm on b series"
Then why are pistons sold .020 and .040 oveR?
