Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 10-02-2004, 03:36 PM
Arkane Arkane is offline
87 CRX suggestions
Hi, I'm new to Hondas and recently bought an 87 CRX with an SiR motor in it. Can anyone tell me what that motor is capable of and if I should go ahead and do a motor swap instead. Oh, the reason I'm asking is because it needs a new flywheel and clutch installed so I was wondering if I was wasting time with the current motor.
Old 10-02-2004, 06:15 PM
Figori's Avatar
Figori Figori is offline
Send a message via Yahoo to Figori
Re: 87 CRX suggestions
Hmm.. SiR... Not real familiar with that motor. There are many choices for the motor swap, all depending upon your budget. So, it really depends on how much you want to spend right now. I later plan on dropping in a b18 shortblock with a b16 head. But that is in the not so near future.
"Short, sweet, and to the point"
1987 CRX Si - Project Si 'RexSi'
1996 Ford Thunderbird 4.6L V8 - Plastic Intake Manifold, FTL.
2004 Nissan Sentra, 1.8s - The "s" stands for smooth....... ?
Old 10-02-2004, 06:40 PM
cvcc_wagon's Avatar
cvcc_wagon cvcc_wagon is offline
SiR? can you get the engine code off it? it's stamped on the front beside where the tranny mounts to the block. an SiR motor is from the newer hondas and it does not mount into the car w/o modification
~Attention! if you are thinking about a D16A1 swap for your Civic/CRX and don't know where to start go Here. Thanks.~
Old 10-03-2004, 07:05 AM
I'll check on it sometime today. It's at a friend's that I work with so I cant check it immediately. The best I can remember, it says sir on the taillights and is stamped where vtech and stuff like that normally are.
Old 10-05-2004, 11:07 AM
87civicfranky 87civicfranky is offline
its a sticker raceing car.......probly some crappy carb or jurasic f/i system.........
