Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 10-02-2004, 02:58 PM
buckwheat2004 buckwheat2004 is offline
Stalling 1995 Neon
I have a 1995 neon that has a code 11 which seems to be a crankshaft position sensor according to the code diagnosis. I have replaced it and the problem is still there. It will run fine for about 5 mile or so. Then it starts stalling out when the rpms are under 2000. I have replaced the EGR vale the camshft position sensor the plugs the wires and the crankshaft position sensor so far. It just recently gave a code 43 which is a multi cylinder miss fire and no check engine light. What else could it possibly be.
Old 10-06-2004, 08:51 PM
just me just me is offline
Re: Stalling 1995 Neon
According to ther list I have it could be all that you checked or a missing tooth on the timing belt
Old 10-18-2004, 07:31 AM
skatendestroy skatendestroy is offline
Send a message via AIM to skatendestroy
your timing is deffinatly off
Old 10-20-2004, 05:10 PM
diebythesword diebythesword is offline
i had the same prob. with my 95 neon. Changed every sensor and all that needed to be fixed was my timing. Now it runs like brand new!
