Old 10-02-2004, 02:54 PM
StEaLtH1991RT StEaLtH1991RT is offline
Question anti-lock brakes
I have a 1991 Stealth R/T TT last year i was driving looking for a gas station that was open during tha black out. well a car ended up pulling infront of me which i hit him on his driver side and my passenger side was smashed up intercooler and such was ripped right off my car the other car was a brand new exployer which had very lil damage to it so i had tha car towed and was all fixxed well one proble i have had ever since was that the anti-lock brake light stayed on all the time the anti-lock seem to be working just fine no problems at all with the brakes just i hate to see the light on all the time cause it makes me think my brakes might just go out.I have tha paper which tells me what dodge replaced for the brakes they installed a new ecu,found that they was a faulty hydraulic i was told that was replaced to says they bleed tha brake system........ i brought tha car back to the dealership because i guess they had to get a special code reader for this car and nuthing came up for any codes or problems so idk what else to do now.....if u anyone has any idea it would help thanks....
Old 10-02-2004, 04:41 PM
Neutrino's Avatar
Neutrino Neutrino is offline
Yaya Master
Send a message via AIM to Neutrino
Re: anti-lock brakes
moved to the proper forum
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your
(")_(") signature to help him gain world domination
Old 10-03-2004, 04:09 AM
BB1970's Avatar
BB1970 BB1970 is offline
its probably a faulty abs sensor on on the wheel you clumped. you have an abs sensor on each wheel. you can test them yourself with an ohms meter. test each one and look for a noticable different reading between them all, one of them will read different to the others and that will be the one thats faulty.
1993 Mitsubishi GTO Twin Turbo (RHD) NOW SOLD!!!
9b turbos with manual boost valve mod set @14psi
turbo xs type h-rfl blow off valve
blitz dome filter
sachs clutch
completely de-catted
fuel pump voltage rewire mod
ebc redstuff front brake pads
greddy fully automatic turbo timer
now drives a sensible family sedan. A 340hp 1997 mitsubishi evolution IV
Old 10-03-2004, 10:58 AM
sLADe781 sLADe781 is offline
BB1970, so can that be "fixed?" ;o/
Old 10-05-2004, 11:32 AM
BB1970's Avatar
Yes but you need to buy a new sensor which can be expensive around $150 i should think might be worth trying a breakers yard for a second hand one.
once fitted the light should go out.
blitz dome filter
sachs clutch
Old 10-05-2004, 11:53 AM
Musashi3000GT's Avatar
Musashi3000GT Musashi3000GT is offline
I agree with BB, my friends Tiburon had the same problem and it was the sensor. in his case it was loose so we simply re-installed it. geeeze $150 for a sensor is kinda rought though!
06 GTO: SLP Longtubes, SLP Loudmouth II K&N intake,
Ported Intake Manifold,
Ported Throttle body, MAF screen delete.
Tunned by Jeremy Formato. 381whp, 376wtq.
07 Ion Redline: Bone stock w/ factory Competition package.
In response to a race my wife had while pregnant with our baby:
Originally Posted by jeepgclwj
Prediction.... I bet we will hear about a guy down in Miami thats the King of street racing in about 18 years...Way to get him started....
Old 10-05-2004, 06:41 PM
StealthModifier StealthModifier is offline
how do u know if u have abs or not?
Old 10-06-2004, 01:58 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
slam on the brakes at 100, no abs and your ront tires will distroy them. but you will leave some of the longest "burnout" marks on the road anyone has ever seen.
Old 10-06-2004, 07:17 AM
Re: Re: anti-lock brakes
crash against an Explorer and after you fix the damage if the ABS light comes on then you have ABS!
Old 10-06-2004, 07:34 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
What trims (dodge and mitsu) came with ABS?
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 10-06-2004, 08:22 PM
GritMaster GritMaster is offline
I think most cars didnt start getting them till like late 80's early mornings?
Edit:\
I'm tired. Meant early 90's thought you said years, probbly all the trims 92+ had ABS, as it was pretty common after that, this is just a slightly educated guess tho.
RIP Andy "Hypsi87" Filson... We'll miss ya mate
Originally Posted by nissanstreetz
For about 700 dollars you can have about 80 horespower at the wheels and about 70 torque.
Old 10-07-2004, 11:13 AM
where is the abs sensor at ??
Old 10-07-2004, 09:31 PM
did 91 dodge stealth es's have it?
Old 10-07-2004, 10:27 PM
check for some badging that would say ABS, probbly on the dash, if it isn't there you probbly don't have it.
have an owners manual? it'd tell you.
or go to one of those car facts sites, I'd do it now but I'm a lazy bastard
Old 10-08-2004, 12:31 AM
mike93vr4's Avatar
mike93vr4 mike93vr4 is offline
look to see if their is a wirg going in behind your rotor or loke to see if you can see ths tone whel looks like a gear it is on your axel shaft
