Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 10-02-2004, 02:21 PM
Black92LudeSI Black92LudeSI is offline
Send a message via AIM to Black92LudeSI
acceleration
I have a 92si auto-
I've noticed on my car that after it warms up, (running for over half hour) that sometimes after shifting into second when I push down accelerator the rpms jump up rapidly, maybe 1/2 rpm. When I push down the pedal after accelerating into 2nd the rpms jump slightly. Its not a problem shifting because it will shift and if i dont push down the accelerator hard it will accelerate normally but if I push it down a little harder I experience the jump. I have bosch platinum plugs which perhaps may be doing it but not sure. I think it may do this other times too, not just after shifting into second. Any suggestions?
Old 10-02-2004, 02:44 PM
joellthomas joellthomas is offline
Re: acceleration
you driving a stick
Old 10-02-2004, 04:53 PM
rubix777's Avatar
rubix777 rubix777 is offline
Send a message via AIM to rubix777
maybe check your throttle is not prevented from rotating freely, you might want to lube it up.
Old 10-02-2004, 11:04 PM
yea its an auto
IT only does this after warming up a good bit. Transmission fluid is fine, its level and has been changed , its a nice red clearish color. So to resumarize the problem (its a little confusing ). When accelerating,, commonly after the car shifts into second, and pushing accelerater a little harder then what is was at before shifting I notice a slight very slight rpm jump. It may do this other times too. If I dont push the accelerator down a little more after shifting into second then it is fine.
Old 10-03-2004, 12:27 AM
rubix777's Avatar
this might be a simple case of regular downshifting that the automatic transmission does.
naturally if you're going up hill or want a little more power, pushing the pedal down further will cause it to downshift for you so that it won't be struggling in its current gear.
Old 10-03-2004, 02:39 PM
I'm positive that its not dowshiting because I can always feel it when that is taking place. Good sugestion on the throttle though because when I first bought the car the rope was half way off that spindle thing. I'm assuming thats what your talking about, i'll check that out..
Do you think it could be the plugs?
Old 10-03-2004, 03:30 PM
k_dog's Avatar
k_dog k_dog is offline
Send a message via ICQ to k_dog Send a message via AIM to k_dog Send a message via MSN to k_dog Send a message via Yahoo to k_dog
Re: Re: acceleration
Originally Posted by joellthomas
you driving a stick
joellthomas: Read PWnZ j00!
Could always be a missfire. I would look into that and your Transmission Fluid being short.
-Brian
