Ever since I've gotton my camry, this problem has seem to be getting worse. Someone help me please. It's A HUGE PROBLEM.
It's a 93 camry le with the top 4 cylinder in it and is a 5 spd manual. My problem is getting worse every month and is starting to really affect my driving. I almost ran into someones bumper. Whenever I'm driving, say in 5th gear, and I let off the gas to decelerate, the car buckles forward and feels like it's loose. So once I'm decelerating and slow down to around 25-20 mph and stopping, the car then feels like it's holding on then suddenly it will buckle forward and backward like it's not holding on to the power no more. It just waves back and fourth, almost in a bouncing motion. So when I come do a stop and then start to move, I can gently press the gas or gun it and the car will bang forward. It's no smooth transaction from slow to fast or from stop to go. I can be doing 30, 45, 55, etc. and it does the same thing, It lurches forward when I hit the gas and buckles back when I let off the gas. Even If I let off the gas slightly or just drop it, the car will buckle back harshly. So the other day when I'm following close to a car and they keep slowing down and gassing it, I'm trying to hit the gas as slightly as possible, but the car will lunge forward and I have to hit the brakes fast cause the I would almost hit the guys bumper. I've been told that the front of the car raises up and down when it lunges forward very high. Same goes for when I let off the gas as slightly as possible, the car will buckle back. It almost has a little hop to it when it does it. I've tryed revving it up in my driveway, in neutral with my ebrake on the car does not buckle at all or the engine doesn't buckle at all either. It's smooth when I let off the gas and smooth when I hit the gas. So it's not the engine, but what? Also, when I'm driving say 45 mph, let off the gas, car lunges forward and then hit the gas, the car will sometimes(only 3 or 4 times a week) skip. It's like I'm pressing the gas, but the car justs bounces forward. It's almost like it's not moving but is trying to but rattles the whole car. The whole car will shudder loudly and the whole chassis will rattlel like a tin can, then it'll move and it's fine. I beg of anyone to help with this. It's getting worse and I have no clue what the hell it could be. Please, any ideas. I think I'm going to cry
1990 Black Geo Storm - RIP - 1990 Blu metallic Std Hatch 1999 Milano Red Ex Coupe Current -- Ex to Si. It's Overdone, but who gives a crap. I don't! |
Re: This is very odd indeed
One possibility that comes to mind with the info provided is a motor mount.Try putting it in first with the e-brake on and try pulling out while someone watches the engine (from the side) for abnormal movment.
Re: Re: This is very odd indeed
Not even close, the problem is obvious, your clutch is smoked, your running off the clutch mount, the clutch plate is completely gone, so the mount bolts are catching and slipping under any change in load. A preety cheap fix normally, but from the sounds of it, your flywheel is probably trashed now too.
Good luck man |
