Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 10-02-2004, 12:28 PM
89tracerman's Avatar
89tracerman 89tracerman is offline
Unhappy Overheat!!!
ok when i got the car the temp wouldnt go over the 1/4 mark today my war when about 7/8 near the red it shut of on my 3 times when i left it on neutral. what could be the prob. and yes i ckecked the water before i left this morning and it was fine. i dont think its the termostat cuz the temp goes up and down. could it be a cooling seal? and how do i know if it is that? or what could be the prob?
my cardomain
Old 10-02-2004, 03:02 PM
Aruba27's Avatar
Aruba27 Aruba27 is offline
Send a message via AIM to Aruba27 Send a message via MSN to Aruba27 Send a message via Yahoo to Aruba27
Re: Overheat!!!
I'm not too sure, but you might want to start by having the radiator profesionaly flushed. even if that's not teh problem, it'll be benificial.
Old 10-02-2004, 03:40 PM
MBTN's Avatar
MBTN MBTN is offline
Send a message via AIM to MBTN
Re: Overheat!!!
Your engine has severely overheated once. Time for a rebuild!
Old 10-02-2004, 10:52 PM
Re: Overheat!!!
how much would a rebuilt cost?
my cardomain
Old 10-03-2004, 12:01 AM
Soyo's Avatar
Soyo Soyo is offline
Send a message via AIM to Soyo
Re: Overheat!!!
http://www.rotaryresurrection.com/
oh, and learn to type
1989 RX-7 TII --- Just got rebuilt and street ported
RB 3" dual exhaust, BNR stage 1 modified factory turbo, FCD, S-AFC II,
720cc secondaries, Aftermarket Turbo inlet duct w/K&N, Hawk HP+ pads
HKS Blow-Off Valve, Stainless brake and clutch lines
Old 10-03-2004, 12:11 AM
Proud-r32-owner Proud-r32-owner is offline
Re: Overheat!!!
Are you using 2 stroke??
Use it, unles u want another fucked up engine
Old 10-03-2004, 01:54 AM
drftk1d's Avatar
drftk1d drftk1d is offline
boost in, apex seals out
Send a message via AIM to drftk1d
Re: Re: Overheat!!!
What the hell?
RX-7 TII
Old 10-03-2004, 01:57 AM
fcdriver fcdriver is offline
Re: Overheat!!!
I'm guessing he means two stroke oil, I've heard that its an ok idea to run at a good ratoi to keep the seals lubed although I'm not sure which oil you would use cause I've never ran it in mine which has never had any overheating issues or oil consumption problems.
Old 10-03-2004, 02:03 AM
drftk1d's Avatar
Re: Overheat!!!
Oh.
RX-7 TII
Old 10-03-2004, 02:12 AM
Re: Overheat!!!
Ok went looking and found that the oil is premix but you need to pre-mix it in a gas can before putting it in your gas to insure a proper mixture.
Old 10-03-2004, 02:31 PM
Aruba27's Avatar
Re: Overheat!!!
um... what? tell me if i'm translating this wrong: it's a proper ratio gas/oil premix that you put into your tank? sorry, your sentence just didnt' make much sence. i think it was the premix pre-mix/gas can gas combo that threw me off.
Old 10-03-2004, 06:05 PM
Re: Overheat!!!
sry I had the name of the premix oil in there but I'm having key board problems and it cuts somethings out and makes my curser go to different parts of a sentence at times, Pettit makes Protek-R oil and redline makes another premix oil but from what I've read its a good idea to mix the oil in with gas in a seperate gas can before adding it to your gas tank on your car, this just makes sure that the oil is mixed before you take off down the road although it will mix after you have driven a while and caused your gas to slosh around. Sry for the confusion.
Old 10-03-2004, 06:11 PM
Re: Overheat!!!
will this help my car from overheating? (premix)
my cardomain
Old 10-03-2004, 06:13 PM
Re: Overheat!!!
Not really all it does is lube the seals like MBTN said if your engine has already overheated then its time for a rebuild.
Old 10-03-2004, 06:33 PM
Re: Overheat!!!
so i should just swap turbo in it.
my cardomain
