Go Back   Automotive Forums Car Chat > Chevrolet > Nova
Old 10-02-2004, 12:02 PM
shannara61 shannara61 is offline
? from a novice
what exactly is a stall converter, what does it do and am i correct that it installs between the engine and trans, also can stall converters be purchased for most engines?
Old 10-11-2004, 02:04 PM
scoutinkeith's Avatar
scoutinkeith scoutinkeith is offline
Send a message via AIM to scoutinkeith
Re: ? from a novice
I'm more of a manual trans guy, but I'll give this a shot. a stall converter is verry similar to a regular torque converter. yes, it goes between the engine and an automatic transmission. the diffirence is that a stall converter needs higher engine speed to "engage" the trans. someone can probably explain this better than I can, but here's how I understand it..... lets say that the stock converter, once the trans is put in gear, starts to move the car at around 1800 RPM. with a stall converter, you'll need higher RPM before the car will move. I'm kinda new to automatics, so I'm sure someone else can explain this better than I have.
Keith
when all else fails, get a bigger hammer.
Vehicles:
2005 suburban 1500 4x4
all stock, ex-fire department truck.
1987 Grand Wagoneer
Old 10-11-2004, 10:20 PM
Robs71Nova's Avatar
Robs71Nova Robs71Nova is offline
Send a message via AIM to Robs71Nova Send a message via Yahoo to Robs71Nova
Yes it goes inbetween the engine and trans and yes you can get them for just about any transmission. Lets say you powerbrake your car. You hold the brakes and press the gas. With a stock stall converter your car will rev up around 1600-1800 RPMS before your tires start spinning. WIth a higher stall converter, say around a 2500, you will be able to press the gas and get the RPMS up to around 2500 before the back tires start spinning. This just lets you have higher RPMS out the hole and provided you have traction makes your car get off the line faster.
Rob
