Old 10-02-2004, 10:06 AM
quiXilver's Avatar
quiXilver quiXilver is offline
Send a message via ICQ to quiXilver Send a message via AIM to quiXilver Send a message via Yahoo to quiXilver
Brake master cylinder?
When I'm at a stoplight, and I have the brakes on, the pedal slowly goes to the floor. Also when I'm braking and i start getting slower, I start hearing clicking coming from one of the brake, not sure if it's the front or back...
http://www.cardomain.com/quixilver09
B18A
-It's always somethin'
Old 10-02-2004, 11:01 AM
RedLineZO6's Avatar
RedLineZO6 RedLineZO6 is offline
Re: Brake master cylinder?
if your pedal drops to the floor, you probably need to bleed your brakes. As for the clicking, you might wanna pulll off your drums and see if a spring or something is hooking on a shoe. It might be your brake wear sensor, but that should make a screeching sound, not a clicking.
Old 10-02-2004, 12:10 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
petal to the floor- check your brake fluid first. Then the wheel cylinders and calipers for leaks, and check for leaks in the line. If all of those check out it could be your booster or your master cylinder.
I'v never heard brakes click before, you sure its not a cv joint?
Old 10-02-2004, 01:59 PM
quiXilver's Avatar
Re: Re: Brake master cylinder?
it's not a cv joint, i've been through plenty of those experiences i can feel it tug whenever it clicks...it sounds like it is in one of my rear drums.
ok thx i'll check for leaks, btw where is the booster or what does it look like?
B18A
Old 10-02-2004, 02:58 PM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Re: Re: Re: Brake master cylinder?
The booster is that large black can behind the master cylinder.
To check the booster check:
here
But I think your master cylinder is the problem.
GL
Old 10-02-2004, 03:35 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Re: Re: Re: Re: Brake master cylinder?
Theres two valves in the master cylinder. The primary and the secondary. One of them may be letting fluid by which will gradually make your pedal go to the floor. Air in the lines causes more of a spongy feeling. As for the clicking, take your drums off, and see if theres any broken parts. also check both of the wheel cylinders to see if their seized or if either of them are leakng fluid.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
