Old 10-02-2004, 10:05 AM
mitsuGTvr4 mitsuGTvr4 is offline
clutch slipping
hi...bad news, ive been noticing taht when i step on the gas, my revs go way up, but i barely accelarate at all..if im not mistaken tha would be my tranny slipping right...i wanna get this taken care of b4 something bad happens.
Old 10-02-2004, 12:27 PM
Getsum3kgtsl Getsum3kgtsl is offline
Re: clutch slipping
Do you have an automatic or manual?
Old 10-02-2004, 05:13 PM
its a manual 6 spd.
Old 10-03-2004, 07:48 PM
Teazrsnow Teazrsnow is offline
Send a message via AIM to Teazrsnow Send a message via Yahoo to Teazrsnow
that would be your clutch
Tyler Laabs
2nd Place Drag racing Fwd 3s National Gathering 03[
Old 10-03-2004, 08:19 PM
ec437's Avatar
ec437 ec437 is offline
Re: clutch slipping
lol it would've been funny had he said auto
SoStAsSaId: and the flight attendant is cute... if i was a lesbian, i'd join the mile high club
<---call this number
Old 10-03-2004, 09:28 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Re: clutch slipping
Time to buy yourself a stage 2-3 clutch lol, is your car stock/close to stock?
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 12-04-2004, 07:26 PM
6g72tt 6g72tt is offline
Re: clutch slipping
fuck i have the same problem too but my car the only thing it has is the k&n filter, test pipe and catback what stage would you recomend me?
Old 12-04-2004, 08:42 PM
Igovert500's Avatar
blue + red light magnet
Re: clutch slipping
go to 3sxperformance.com look at thier clutches and decide based on your hp
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 12-05-2004, 02:44 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
hold up~!!! it sounds like it COULD be your clutch slipping. HOWEVER, it could also be your MASTER/SLAVE clutch cylinders. my slave gave out, but since the clutch hadn't been replaced in 70k miles, i replaced both of them. i got my clutch for $120 from eClutchmaster.com--> OEM Exedy clutch. works great!
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 12-05-2004, 02:54 PM
Re: clutch slipping
hey thanks dudes for the help ill look for it and yeah y had some problems with the master clutch cylinder im going to check that out thanks
