Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 10-02-2004, 09:36 AM
WHENINDOUBT WHENINDOUBT is offline
1997 Bonneville Heat Inop
Hello All, I Have A 1997 Bonneville With A Inop Heater. It Blows Cold Ait Only. The Temp Is Reading 180 Ish. The Fan Blows But No Heeat, Coolent Level Is Good....any Ideas ?? Thanks!
Old 10-02-2004, 05:11 PM
markwb's Avatar
markwb markwb is offline
Re: 1997 Bonneville Heat Inop
Do you have climate control, or manual controls? The air mix door may be malfunctioning. Do you have air flow out of the heater outlets? Have you checked the heater supply & return hoses (at fire wall) going into the heater core to see if they are warm or hot?
Mark
2003 Pontiac Bonneville SSEi, 1999 Ford Escort SE, 5 Speed
IBEW Local 261 Groton, CT
Old 10-04-2004, 09:13 AM
it has manual controls and seem to work the air is coming out the vents but is not hot just outside air temp
Old 10-04-2004, 11:58 AM
86TATpi 86TATpi is offline
Sounds like a problem with the blend door.
Old 10-04-2004, 12:12 PM
how do you get to the blend door?
