Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 10-02-2004, 02:54 AM
alexortiz82 alexortiz82 is offline
Caprice Ridin' Tooo Low
I want to pick up my 84 caprice body as I have noticed it is riding too low on the ground. A buddy of mine suggested installing Cadillac springs to lift the body a bit. My question is,if I do that, do I also need to replace the shocks?
Old 10-02-2004, 05:13 AM
TommySS TommySS is offline
Re: Caprice Ridin' Tooo Low
is it currently stock?
Old 10-02-2004, 02:37 PM
Yes. Everything is stock.
Old 10-02-2004, 02:49 PM
I replaced my springs/shocks at 167k but there was still a "tilt" to it. The rubber frame isolators need to be replaced on mine for sure.
You have to remove the shocks to get to the springs, so as long as they're off, replace them too.
Also make sure you're running a stock tire size.
Old 10-08-2004, 08:12 AM
guy1138 guy1138 is offline
The best solution would be to use the polie car springs & shocks. They're bilstien shocks, and are noticeably stiffer than the stockers, and give the car a higher ride height.
The parts store should be able to give you the right ones if you tell them it's for a police car. The SEO code for the cop car is 9c1
