Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 10-02-2004, 12:25 AM
mikester_91 mikester_91 is offline
Distributor rotor
I just tried to change the rotor on my 92 lude, and it seems the screw holding it in is stripped to all hell. I tried to get it out for like an hour and the son of a bitch wouldn't come out. Any suggestions on how to get it out?
Old 10-02-2004, 01:52 AM
ProjectPhantom's Avatar
ProjectPhantom ProjectPhantom is offline
Re: Distributor rotor
wd40?
Old 10-02-2004, 02:01 AM
94PreludeJDM's Avatar
94PreludeJDM 94PreludeJDM is offline
they do make this stuff called Liquid Wrench. My dad has it and it seems to have worked everytime we've needed. Try looking into something along those lines.
Old 10-02-2004, 09:02 AM
joellthomas joellthomas is offline
is it a hex head bolt or phillips head screw. i assume the head is rounded and a socket or screwdriver will not hold. the threads are siezed and need some help. use some penetrate as suggested, over night is good. tap on the center of the bolt with a punch and hammer to loosen the threads. an "impact hammer driver" is made for stuck screws and bolts. a chisel and hammer may be needed if the head gets mangled to bad for a tool to fit, and the last recourse is to drill and use an "easy out". patience is the key, a professoinal may be needed, for the bolt or the patience?
Old 10-03-2004, 04:25 PM
It's a philips head screw, and i'm pretty sure the threads are fine.......just the head of the screw is stripped out and a screwdriver won't get it out.
Old 10-03-2004, 04:36 PM
k_dog's Avatar
k_dog k_dog is offline
Send a message via ICQ to k_dog Send a message via AIM to k_dog Send a message via MSN to k_dog Send a message via Yahoo to k_dog
Re: Re: Distributor rotor
Craftsman makes a Bit set that digs into stripped screws. I would look into getting that.
-Brian
