Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 10-01-2004, 10:18 PM
Scott Guberman Scott Guberman is offline
1995 Cutlass Supreme VIBRATION 40-65 MPH
vibration at 40 to 60mph (only while accelerating)and also a little miss/rough on take off. I replaced all 4 tires and had them balenced also replaced rh CV shaft. Could this be CLOGGED Fuel injectors??. Just swaped out transmission too.Replaced plugs also.HELP!!
Old 10-02-2004, 10:19 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 1995 Cutlass Supreme
have you checked the front hub bearings? They will cause a vibration at a specific speed range just like an out of balance tire. Also check for a bent rim.
Old 12-01-2007, 02:16 PM
95CutlassSupremeSL's Avatar
95CutlassSupremeSL 95CutlassSupremeSL is offline
I can think of only one thing, In my olds. at the 100k mark, the engine mounts started going bad. It would do the same thing when I stepped on the gas only, replaced them, is fine now
Old 12-01-2007, 02:20 PM
CA Cutlass Supreme's Avatar
CA Cutlass Supreme CA Cutlass Supreme is offline
hairo.
I had the dogbones (directly in front of the motor and easily accessible) replaced that hold the motor in place in the front. Shouldn't be hard to do with a crow bar and a friend.
Before that the rubber had shrunk and hardened and the engine would rock in the compartment.
1993 (Calif. model) Cutlass Supreme "S", 3.1 Liter V-6, Multi-Port Fuel Injection, 4 speed (AT), Vin "T" motor, NO Tach. 168k+ miles.
Closed Thread
