Old 10-01-2004, 04:43 PM
Lax n Brew Lax n Brew is offline
Send a message via AIM to Lax n Brew
Intake didn't take...
I posted before about me getting a cold air intake for my 94'... I got it, but there is a problem. The MAF sensor doesn't fit in it! When I tried modifying the MAFS, I broke it... So for the past week I've been driving w/out one. It works fine, no problems w/ the car running, but I would like to get one that fits in the intake. Does anyone know where I could buy a Mass Air Flow Sensor for a 94' Talon, that would fit in an aftermarket CAI?
Or if not, is it ok to drive w/out it for long? I've made a few long drives since I took it out, and there have been no problems. The check engine light stays on, but thats just because there is a missing link (since the cord isn't hooked up to anything). I could make it so the light goes off, but I dont want my car to blow up or anything.
Have any of you had this problem w/ a cold air intake in your cars?
What did you do to fix it?
Is there a cheap way to do it?
Thanks!
Old 10-01-2004, 08:06 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: Intake didn't take...
just get a stock size k&n filter to replace your stock filter. then use a silicone coupler to bolt the hard pipe to your stock mas. make sure you cut out the silencer. youll have to have the filter inside the box to hold it but you can cut out most of the box. i wouldnt thiough because it gets more hot air then cold IMO.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
