Old 10-01-2004, 04:18 PM
lilmsEclipse lilmsEclipse is offline
still smoke?
I have a 96 mitsubisgi eclipse rs and just had the lower part of the engine redone(head gasket, timing chain, waterpump.) and its still smoking. What can i do?
Old 10-01-2004, 04:20 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
Re: still smoke?
what color smoke?
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 10-01-2004, 05:28 PM
its gray smoke
Old 10-02-2004, 01:21 AM
helliviknow's Avatar
helliviknow helliviknow is offline
Send a message via Yahoo to helliviknow
Re: still smoke?
did you have the piston rings, valve seals or any of that bs replaced? sound like its burning light amounts of oil and its not comming out thick and looking grey... you notice it loosing a bit of oil here ad there? peace
2006 Isuzu I-280 (Colorado/Canyon Clone)
AR 15" Baja's
K&N FIPK
Old 10-02-2004, 07:55 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Re: still smoke?
if the car was put together right it will smoke anywhere from a couple hrs to a day... i know my car smoked for a good day before i noticed it was gone, i guess thats what happens when you use a complete qt of ATF and a good amount of assembly lube! i made sure there would be no part that wasnt lubed besides the back side of the bearings so they wont spin.
now if they just did a headgasket replacement then you probably still have water/moisture in the exhaust, go beat on your car a little, high RPMs get that exhaust cleaned out! check all your fluids first to make sure they are all at optimal level and make sure there are no fluids mixed... WATCH your temp gauge! good luck
