Old 10-01-2004, 03:13 PM
TOM TUTTLE TOM TUTTLE is offline
Unhappy Stalls When Not Given Gas
I Have A 1995 Caravan Which Runs Really Well When Given Gas. It Stalls At Stop Lights, Breaking Around Corners, Etc. Italways Starts Right Back Up, But Continues To Stall Depending On Driving Conditions. I've Had The Map Sensor Changed With No Luck. Put Carb Cleaner In It With No Luck. Sometimes The Check Engine Light Comes On, Sometimes It Doesn't. I Need Direction For Next Fix. Don't Want To Spend Money Blindly.
Old 10-01-2004, 08:28 PM
vipergg vipergg is offline
Re: Stalls When Not Given Gas
Sounds like a dirty IAC motor , you should have this pulled off the throttle body and cleaned and or replaced if cleaning doesn't clear it .
Here is another site and sounds like your problem , and they also say to check the IAC . http://www.2carpros.com/topics/iacvalve.htm
Old 10-02-2004, 07:10 AM
Re: Re: Stalls When Not Given Gas
[quote=vipergg]Sounds like a dirty IAC motor , you should have this pulled off the throttle body and cleaned and or replaced if cleaning doesn't clear it .
Here is another site and sounds like your problem , and they also say to check the IAC . http://www.2carpros.com/topics/iacvalve.htm[/Q
ANY IDEA AROUND HOW MUCH AT A GARAGE THIS WILL COST ME? I'M JUST CURIOUS. $50, $100? BECAUSE I'M NOT A MECHANIC.
Old 10-02-2004, 06:38 PM
Chimster Chimster is offline
Well, and IAC motor for my 1996 Voyager (2.4L 4cyl.) is $94CAD
