Old 10-01-2004, 03:10 PM
cbell77 cbell77 is offline
engine swap Skyline gt
Is it possible to put a skyline gt engine in a eclipse?
1966 mustang for sale asking $7900 call 757-766-3702
Old 10-01-2004, 03:45 PM
Partizan's Avatar
Partizan Partizan is offline
Re: engine swap Skyline gt
Yes, u can get almost any engine with money, but it would probably be expensive, and the 4g is already a good engine.
Old 10-01-2004, 04:15 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
actually i dont think it can be done, the motor is to long and with the RWD tranny there would be a big gaping hole is the dash and fire wall. al and all its not worth it.
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 10-01-2004, 04:19 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
ya sure. i saw one once. no wait, that was the other dumbest thing i ever saw...
j/k... but really... why would you want to do that?
Old 10-01-2004, 05:34 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
You can do anything if you have the money, which you don't. Why WOULD it be possible to fit a 6cyl nissan into a 4cyl mitsubishi? who the hell would do that?
Old 10-01-2004, 08:21 PM
o*HeR()'s Avatar
o*HeR() o*HeR() is offline
Banned
Re: Re: engine swap Skyline gt
sombody with alot of money
Old 10-01-2004, 09:14 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
plus with the money that it took to do the swap could make you faster then you would ever be with that stock skyline motor
Old 10-01-2004, 11:34 PM
imtheoneandonlyD's Avatar
imtheoneandonlyD imtheoneandonlyD is offline
Send a message via AIM to imtheoneandonlyD
sounds like something straight out of F&F.
Pictures of the Truck
Old 10-02-2004, 04:57 PM
2of9 2of9 is offline
yeah it does, i think anything is possible with money. But if u were to put a RB25DET (Skyline GTS-T) engine into a Eclipse, u'll need lots of motor mounts, and other important things to support the i-6 engine.
"i told you it was third, I lengthen the injector pulse another millisec and tuned the NOS timer, and you'll run nines"
--2OF9--
(DSM team specialist) ;D
#808/1000
Old 10-03-2004, 10:58 AM
Zero8985's Avatar
Zero8985 Zero8985 is offline
Send a message via AIM to Zero8985
If your planning on doing a swap like that... i'd suggest swapping your engine with the 6.6l duramax diesal out of Silverado 2500hd. The difficulty of the install should be near the skyline engine, maybe a little harder, but look at it this way, it's a turbocharged v8, it's a 605ft. lb of torque bolt on, and since it's diesal, it will prolly be fuel efficiant!
EDIT: Plus it will have that low deep rumble everyone's looking for.
Obviously j/k, but if you wanna do a swap like that, than you also might wanna suggest removing what you said about buying a gsx and start looking, cause with the money you'd spend, you can buy a couple of nice gsx's.
*1997 Mitsubishi Eclipse Spyder GS /// SOLD
*1997 Jeep Grand Cherokee Limited
*2000 Chevrolet Cavalier Z-24 Convertible
My Spyder on Car Domain! Check it out!!!
My Jeep on Car Domain! Check it out!!!
