Old 10-01-2004, 03:03 PM
metallica21156's Avatar
metallica21156 metallica21156 is offline
Obd1.5
is there any way to convert the 1.5 OBD computer to a OBD2, such as switching it out. what would have to be done? 95 4.3liter V6 CPI. doing for performance reasons. would putting a performance chip in allow me to change setting or not?
Old 10-01-2004, 03:46 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Obd1.5
Don't start doing that crap bro.
Our computers are technically OBDII but just a more primitive version installed initially when they were doing the switchover.
Those chips don't do anything for the performance anyways.
Do the usual intake/muffler/under-drive pulleys etc.. before you start frigging around with the computer.
Old 10-01-2004, 09:29 PM
Re: Obd1.5
i'm working on the intake now and the exhaust is done.as well as the EGR mod. what do you mean by under-drive pulleys? never heard of it. i was also thinking of the fan conversion and a 180 thermostat, and installing 1.6 ratio roller rockers from comp cam and a MSD ignition. sound good?
Old 10-02-2004, 02:10 PM
BlazerLT's Avatar
AF -Advisor
Re: Obd1.5
Ok, first off, you really need to come down to reality bro.
1.) Take that stupid EGR mod off. Does nothing but cause detonation You will get more horsepower from a properly work EGR system. If you riase combustion temperature, you will get spark knock and your knock sensors will retard the timing and therfore net you LESS horsepower.
2.) Google for underdrive pulleys and learn about them. www.google.com
3.) Fan Conversion is not worth it. The pully fan is only on when you are at idle and the clutch disengages when you accelerate.
4.) 180 Thermostat - Good Mod Don't go any colder, 180 is the lowest you want to go.
5.) Roller rockers are not needed on our truck. We already have roller tipped lifters.
6.) Comp Cam - Can be worth while if you want to do all the work needed for it.
7.) MSD Ignition - Not needed for a stock and non-turbo or supercharged motor. Stock ignition can supply enough voltage for a 454 and is essentially overpowering the 4.3L.
Put the money into some nice wheels and tires for your truck.
Old 10-02-2004, 09:30 PM
Re: Obd1.5
k thanks for the info. how much of a diff would the under drive pullys make? where can i find a set and whats the price? the roller rockers i was talking about would come from comp cam. would it make any diff or not? i might add a cam later down the line but not now. wheels and tires will come later after the trucks paid off.
Old 10-02-2004, 09:51 PM
BlazerLT's Avatar
AF -Advisor
Re: Obd1.5
Put the money into paying the truck off.
I would rather have a paid off stock truck than a modded trucks with 3000 still owing.
Old 10-02-2004, 09:55 PM
Re: Obd1.5
yea i know but i'm asking for some stuff for christmas.i'd still like to know about the diff would the under drive pullys would make and about the roller rockers.
Old 10-02-2004, 09:57 PM
cobra1 cobra1 is offline
Re: Obd1.5
to answer your question,
yes it can be "converted" to OBD2, however you will have to make a trip to the dealership and have the computer flashed. it wont gain you anything other than full OBD2 compliance AFAIK.
as for a performance chip, JET makes a module that plugs in to the computer.
Old 10-02-2004, 10:00 PM
Re: Obd1.5
would i be able to mod the computer as if it was a OBD2 computer? ball park price?
Old 10-02-2004, 10:25 PM
BlazerLT's Avatar
AF -Advisor
Re: Obd1.5
The JET chip is worthless on our engines.
It just kills your economy and throws in more fuel for power.
Waste of money.
Jesus man.
Old 10-02-2004, 10:28 PM
Re: Obd1.5
i understand about the chip but cobra1 was talking about reflashing the computer to OBD2. that was what i was talking about. i'm not going to put a chip in.
Old 10-02-2004, 10:32 PM
BlazerLT's Avatar
AF -Advisor
Re: Obd1.5
You have to understand, we have a OBDII already.
There is no such thing as OBD1.5.
Our version of OBDII is just a little simpler than the 1996.
Old 10-02-2004, 10:38 PM
Re: Obd1.5
then how come when i hook up a programmer i can't play with the computer like a OBD2 computer. could i reflash it to a newer version of OBD2?
Old 10-02-2004, 10:44 PM
BlazerLT's Avatar
AF -Advisor
Re: Obd1.5
We have a VCM-A which is different than the full OBDII.
Old 10-02-2004, 10:45 PM
Re: Obd1.5
can you explain it any better. can it be switched to a newer version or not?
