Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 10-01-2004, 03:02 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Idle surging both in and out of gear.
Here we go again......86 MGM, 5.0 liter, 140K miles. New idle air valve. In good state of tune. Clean air filter. Fuel pump/filter ok. No vacuum leaks that I've found.
On the gas, smooth as always. At idle however, in or out of gear, the idle surges, first dropping low and running rough enough to sometimes shake the engine, then coming back up to normal, then repeating. Cycle takes about 3-4 secs each time. Other than that no problems.
Any ideas about THIS idle problem?
Thanks in advance......
Old 10-07-2004, 04:50 AM
auto trainy auto trainy is offline
Re: Idle surging both in and out of gear.
Try cleaning the egr valve and then check for carbon build up.
Old 10-07-2004, 08:09 AM
Thanks, will do. Hope that'll cure it.
Old 10-13-2004, 11:24 PM
88Marquis 88Marquis is offline
One of the problems i'm having as well and hopefully we'll find the solution quickly..does your car stall when cold? and shutt off after a stop if you dont wait to warm up for a while?
Old 10-14-2004, 05:19 AM
Nossir, mine never had a cold problem, all the problems were across the board, hot or cold.
