Old 10-01-2004, 01:46 PM
dankid dankid is offline
Fog Light Cover
I have a 96 Eclipse GS and recently I did a 97-99 front end conversion. I bought an aftermarket bumper off of ebay for cheap that fit perfect. My only problem is that the bumper did not bring the plastic pieces that cover the big holes if you don't have fog lights. I put wire mesh and it looks better but i'd like the plastic pieces better. I've done a search everywhere and can't find these inserts. Does anyone know where I can get these??
Old 10-01-2004, 01:59 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
Re: Fog Light Cover
the dealer. but they require mounting screws and clips, so you might want to make sure you are porperly setup.
i just dremeled them so that they are basicalyflush to the bumper. no back stuff. in your case i would dremel it, but leave some 'tabs' so that you can mesh it right. the inserts i have never liked. mesh just looks better
Old 10-01-2004, 02:44 PM
Re: Fog Light Cover
Cool. Thanx for the help.
Old 10-01-2004, 08:14 PM
george536's Avatar
george536 george536 is offline
Re: Fog Light Cover
the dealer charge me 23 bucks for only one.
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 10-02-2004, 11:19 AM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
Re: Fog Light Cover
i would fabricate my own covers....worth a try.
The daily driver. The weekend cruiser. The lazy shop hog.
Old 10-04-2004, 10:17 AM
Re: Fog Light Cover
I went to the dealer this past weekend and they wanted 18 per cover and they only had the left side cover in stock. I guess i'm gonna just keep the wire mesh i have on right now. I might try installing some fog lights behind the wire mesh.
