Go Back   Automotive Forums Car Chat > Kia > Sephia
Old 10-01-2004, 12:58 PM
cubertja cubertja is offline
2000 Sephia - check engine light blinking
My car is sputtering and check engine light is blinking intermittently.
Any ideas? Thanks
Old 10-02-2004, 02:54 AM
SupaMan89T's Avatar
SupaMan89T SupaMan89T is offline
Send a message via AIM to SupaMan89T Send a message via MSN to SupaMan89T Send a message via Yahoo to SupaMan89T
Re: 2000 Sephia - check engine light blinking
Any ideas? Thanks
that has happened too my aunts car and we found out that the valve cover gasket blew out and was leaking oil into the #2 spark plug chamber maybe thats whats wrong with yours
Project Lexus Revive
Old 10-04-2004, 10:51 AM
Any ideas? Thanks
Thanks for the info. Did you repair it? if so, how costly?? thanks, JC
Old 10-17-2004, 02:46 AM
kyle95g20 kyle95g20 is offline
the check engine light flshes when the vehicle is experiencing a misfire. this is in most cases caused by fouled spark plugs, yes a bad vc gasket seeping oil onto the plug will foul it. in most cases it is just becasue the plug is worn out. sometimes it is the valve cover gasket like the guy above said and sometimes it is the coils have gotten stressed and the bodies on them have cracked and the spark is arcing elsewhere besides the plug.
if you are mechanically able-it is an easy fix. if you are not so inclined take it in and it should be easily erpaired for you. at most dealers all of those parts should be in stock. i know they are at mine.
gone through so many cars i can't keep track. all i know is i have a gsr swap on the floor of the garage that is going in a teal boxy hatch.
Old 11-24-2004, 06:06 PM
chiefkyle chiefkyle is offline
Re: Re: 2000 Sephia - check engine light blinking
Originally Posted by kyle95g20
.........at most dealers all of those parts should be in stock. i know they are at mine.
How much are they at the shop. I looked on KIA's site, and it looked to be about $50.
When mine misfired (two seperate time) on two different plugs, my Engine light stayed on.
BTW: Mine was caused by leaking oil into the plug.
Old 11-24-2004, 09:18 PM
what part(s) specifically?
Old 12-15-2004, 01:59 PM
Sorry kyle95g20, I was reffering to the Valve Cover Gasket. I went and bought one at the Kia Dealer. Cost me $50.07. Sime to install, and haven't had a problem with miss fireing plugs ever again.
Old 11-11-2010, 03:54 PM
melisaire melisaire is offline
I have a 2000 Kia. Today on my way home from work the check engine light came on and the o/d off light started to flash. I am worried that it might have to the tranny.
