Old 10-01-2004, 12:48 PM
grandam1 grandam1 is offline
Heat not working
1990 Grand Am 4 cyl.
Blower works, changed thermostat.
Heat does not work. Checked Chiltons & Haynes, no help.
Is there a heater valve/solenoid? Thanks in advance.
Old 10-01-2004, 04:19 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Heat not working
your hot to cold selector is cable operated. the cable may be broke or disconnected. trace the cable from the heater control to the door actuator rod and see if it's moving.
Old 10-14-2004, 07:21 PM
smackattack smackattack is offline
How long have you had car? If its a new to you car check to see if last owner bypassed the heater coil.
