Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 10-01-2004, 10:20 AM
tnohe1 tnohe1 is offline
97 wrangler's oil pressure gauge goes down
I just bought a 97 wrangler, and when I was driving on the highway I noticed the oil pressure gauge go down when I came to a stop. It didn't go all the way down, but close to it. Is this an oil pump problem, or the oil gauge itself? What can I do?
Old 10-01-2004, 12:52 PM
gtmud gtmud is offline
Re: 97 wrangler's oil pressure gauge goes down
First and IMMEDIATLY! Put an oil pressure guage on it to see what your actual pressure is. If this checks out, look into replacing your sending unit. I wouldn't drive it till you know for certian that your oil pressure is good.
Old 10-09-2004, 10:41 AM
TJ-Dave TJ-Dave is offline
I have recently purchased a 97 4cyl and had the same thing happen to me. Change the oil/filter with 10w30, no change. I replaced the oil sensor and it read better but still fluctuated quite a bit. Drained oil/filter and used 20w50 which seems to have solved the problem. I live in FL and do not have to contend with the cold so I am not concerned with the heavy oil during start up. Hope this helps. Good luck.
Old 10-10-2004, 11:18 AM
goinbig goinbig is offline
Send a message via AIM to goinbig
It's a Jeep Wrangler. This is a very common problem, and probably 99.99% of the time you just have to live with it.
If the oil pressure drops to Zero, then you've got problems.
My '88 and '89 YJ's would both drop down and run a 5-10 psi quite often!!
