Old 10-01-2004, 08:56 AM
Harmonix Harmonix is offline
Send a message via AIM to Harmonix
89 Grand Am will not start
89 Grand Am will not start. It was working fine after putting in a new oil pan, new exhaust, and new battery. before it broke down it would stall when trying to take off from a complete stop.
Old 10-01-2004, 10:28 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 89 Grand Am will not start
What size engine do you have. Check the crank position sensor you may have damaged it when you removed the oil pan.
Old 10-01-2004, 05:23 PM
its a 2.3. I'll make sure and check that. Where is the Crank Position sensor located at?
Old 10-01-2004, 06:01 PM
Pontiac Guy
It is located on the engine block just above the oil pan rail. The book doesn't say whether it is front or rear. It may also be located on the timing chain cover near the vibration damper.
