Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 10-01-2004, 08:23 AM
DUlrich1227 DUlrich1227 is offline
Send a message via AIM to DUlrich1227
Thinking about doing a rebuild...
I have 96 JGC 6cyl 4.0 laredo @ 124,000 miles ..
I am thinking about doing an engine rebuild and interior but not sure where the heck to begin
any suggestions , web links anything would be apprectiated..
I have had some odd problems with car errratic oil pressure ... needs a fuel pump that kind of stuff ( i have posted before ) I have some extra money so figured i mine as well do some kind of rebuild... want a little performance and another 100,000 miles
PLEASE ANY TIPS / TRICKS / PARTS / PICS / WEB LINKS WOULD BE
GREAT !
Need a good push in the right direction ...
also anyone in s. fla ?
David
Old 10-02-2004, 03:54 AM
ChadEbert ChadEbert is offline
Re: Thinking about doing a rebuild...
you're rebuilding a 6 with that low of mileage? Seems odd, I got 297,000 out of my last 6. is it really worth tearing down? Thats a big job.
Old 10-02-2004, 06:48 AM
well i guess i am not to sure where to begin than....
I want to get a little more perfroamance out of it...
I have an odd oil pressure thing going on...
- whn the engine heats up afer (after driving for @ 20-30 min ) at idle the pressrue will drop if i hit the gas it will go back up
The enginge sounds " loose" I heare a lot of tapping / rattling going on inside... --thats the only way i can describe it.
So i guees i am unsure of exactly what i want to do or where to start....
Old 10-02-2004, 08:28 AM
When the engine heats up, the oil pressure will do that. When you are at idle, there's little pressure, when you accelerate, you are forcing oil thru so of course the pressure is going to increase. What is the pressure "dropping" to and when you are accelerating, what is it at then? Sounds relatively normal to me.
The tapping/rattling inside the engine could be lifters hanging up, might just want to have a mechanic take a peek at it. But to rebuild an I-6 at 124K is unheard of unless the thing has been beaten to a pulp and not taken care of.
Old 10-02-2004, 10:14 AM
Re: Re: Thinking about doing a rebuild...
the pressure drops to 0 and the light comes on ...
if i change the oil it wont do it for about a week...than starts up again
it only drops if i hit a red light and its at idle...if i tap the gas goes up and light goes off
Old 10-02-2004, 11:19 AM
what weight oil are you using? Is the crankcase full? Might be an oil pump issue or a sensor switch. Again, if you have enough money for a rebuild, you have enough to take it to a mechanic and have these few issues resolved.
Old 10-02-2004, 11:24 AM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
yea it shouldbn't get that low, the tapping ur hearing, it is b/c your not getting enough oil to the Lifters, try replacing the Oil pick up screen on the oil pump, or cleaning it out. this will help, it could also be the oil pump going bad and not pumping enough oil..
try to clean the Screen 1st or put a new one on, if that don't help u may want to get a new Oil Pump.
Old 10-03-2004, 11:05 PM
oil pick up screen ? is that in the pan ? i am assuming i need to take the pan off...
Old 10-04-2004, 11:50 PM
Yes, the Oil Pump Pick-Up screen is on the Oil Pump inside the Oil Pan. and it is kinda a b!@*h to get off.
a coupl etips. jack the front end up so that the wheel are off the ground, but don't jack on the axles, u need the tires to hang as low as they can, and then whenu are done unbolting the pan. jack up on the tranny bell housing so it will give u enough room to slide the pan between the Tranny and the Ehaust. email me if u need any info Joe [email protected]
