Old 10-01-2004, 08:21 AM
Ron M Ron M is offline
Send a message via Yahoo to Ron M
2002 S-10 service engine soon light on
2002 S-10 check engine light is on took it a shop they said #5 cylinder dead they put in a new spark plug theat didn't help they told me to put a new #5 wire on, I did that didn't help either, I also put on a dist cap and rotor, that didn't help either then I put in some fuel injection cleaner no help either, what to do now? it has 38,000 serviced regulary and taken care of, please help.
Old 10-01-2004, 09:34 AM
Mikado14 Mikado14 is offline
Re: 2002 S-10 service engine soon light on
Do a compression check on #5 cylinder.
Old 10-01-2004, 11:26 AM
that was my next step, but thought it might be something more simple, thanks, Ron
Old 10-01-2004, 04:04 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Get the actual code for us and not just the mechanics description of it.
If it is a cylinder #5 misfire, chances are you need to change that injector out for one that doesn't have the end poppet valve clogged.
Here is the injector, take about 1 hour to swap out.
http://cgi.ebay.com/ebaymotors/ws/eB...category=33557
If it is that cylinder misfire, first check for spark going to that cylinder by sticking a screwdriver into the plug wire and hold it about 1/4 inch from a ground source and look for spark.
If you have spark, you have no fuel in that cylinder and you just swap out the injector.
Old 10-01-2004, 09:21 PM
thank you I will try that.
Old 10-02-2004, 02:01 PM
BlazerLT's Avatar
AF -Advisor
Come back here and tell us also.
We need to know when a fix works.
Please don't just ask for help and screw off.
We need feedback.
Old 10-02-2004, 05:40 PM
well, I'm not screwing off, I'm on disability and I can't afford to buy a injector yet, and when I do I will be very sure to come back and let you know what happened.
Old 10-02-2004, 09:47 PM
BlazerLT's Avatar
AF -Advisor
Excellent.
Actually, you could pull one off of a wreck if you want.
Much cheaper.
Old 10-12-2004, 08:45 AM
from what the mechanics are telling me here is that with mine I have to take off the intake manifold to replace it, I have a 2002 S-10 with the vortech V-6, is this right? thanks Ron
Old 10-12-2004, 01:26 PM
BlazerLT's Avatar
AF -Advisor
NO, the injector pos is between the intake and the distributor on top of the engine.
I suggest buying a Haynes or Chilton Repair manual for this repair, it is $15 and tell you step by step what to do.
Old 10-12-2004, 08:09 PM
ok, thanks a lot, I will go buy one tomorrow.
Old 10-13-2004, 09:28 PM
I got the injector today but the books only go up to 2001, will that be the same as my 2002? thanks Ron
Old 10-13-2004, 10:14 PM
BlazerLT's Avatar
AF -Advisor
Yip, pretty well exactly the same other than the computer which doesn't affect this repair.
Old 10-13-2004, 10:54 PM
thanks I will get one tomorrow, thanks for all your help.
Old 11-06-2004, 05:49 AM
I put it in yesterday and it works great, thanks for all of your help,
