Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 09-30-2004, 11:30 PM
010175 010175 is offline
I want to buy a code reader.
I am going to buy a code reader this week. I want to spend less then $200. Do they all check transmission codes? Do I need one that does any special readings? Any brands should I stay away from. Thanks for the information. Dave
Old 10-02-2004, 11:52 PM
trannyman52 trannyman52 is offline
don't waste your $$$$$ on a code reader,,,,,,when one thing faults,,,generally other controls will fall out of spec,,,,,thus you will see
a list of things wrong,,,,,,the problem then is WHICH fault is the REAL
problem,,,,,and which are phantoms???? obd-1 was good for that,,,obd-2 not quite as bad
Live data tester much better bargain!!!!!!!
Old 10-07-2004, 01:52 PM
slacker_53's Avatar
slacker_53 slacker_53 is offline
I have an OBD II reader from Innova, the 3100 model for 1996 and up, and I use it all the time. I gave $ 89.95 for it, but I think the price has gone up somewhat.
It's great for finding codes and putting the light out. Sometimes your vehicle will get a momentary glitch in the system and if you put the light out, it may not come back. It has definately saved me some bucks. Works great for me!
-slacker
When I die, I want to die peacefully in my sleep, just like my grandfather................not yelling and screaming like the other people in his car!
http://www.geocities.com/tbuckit1/index.html
Old 01-15-2005, 07:16 AM
consumer22 consumer22 is offline
code reader
I have the same model. Couldn't be happier with it. It is amazing how many new friends will also need to use it.
