Old 09-30-2004, 11:05 PM
caniborrow50cnts's Avatar
caniborrow50cnts caniborrow50cnts is offline
Send a message via AIM to caniborrow50cnts
Need help identifing engine noise!
For starters, I have a 97 eclipse, 2.0 non-turbo, stock with the 420A engine. No mods at all.
During acceleration from about 2500 to 7500rpm, I can hear a high pitched whistling sound coming from the engine. I know it is not neither the alternator nor the PS/AC belts since I took those off and it still made the noise. I can shift into neutral and it will still do it when I rev the engine. I have also noticed it only does this during acceleration. The car does not have to be moving for it to sound. I have narrowed it down to two possibilities but I wanted to get your opinions before I started pulling it all apart. Any other questions or descriptions needed, just post and I will reply. Any help is appreciated.
72 Beetle - trashed
88 Escort EXP - dumped
92 Talon - sold
97 Eclipse RS - still own
99 Eclipse GST - still tearing up the asphalt
Old 09-30-2004, 11:42 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Re: Need help identifing engine noise!
check all your vacuum hoses... sounds like a vacuum leak! expecially the hose running from the valve cover to the manifold
Old 10-02-2004, 12:12 AM
I thought it may have been a vaccuum leak though but when I checked them, they seem to be just fine. I will check the manual though to make sure something isnt missing because that just seems to be the most likely cause. Any other thoughts out there?
72 Beetle - trashed
92 Talon - sold
Old 10-02-2004, 12:48 AM
mustange kiler mustange kiler is offline
my car makes the same noise i havent check yet because i like the sound of it
Old 10-02-2004, 12:49 AM
it sounds like its comming from the right side when im driving
Old 10-02-2004, 12:51 AM
i know, it sounds like a turbo charger but without the blow off valve. Reguardless I still think it would be better to locate the problem.
72 Beetle - trashed
92 Talon - sold
