Old 09-30-2004, 10:08 PM
cap503fd cap503fd is offline
Send a message via AIM to cap503fd Send a message via Yahoo to cap503fd
electrical fuel problems
i have a 1991 RS 2.7 i think V6 injected......this is a intermentant problem..no rime or reason. when i turn on the key and i hear the fuel pump humm i know it is going to start. when i don't hear it, it wont start. sometimes i am just driving and the engine will stop running. i will pull over and shut everything off and it will restart sometimes right off the bat after about 15 seconds. other times it will take 15-20 min then it will restart. i have replaced the fuel relay but that didn't help. i know it is electrical because i have (and probably shouldn't have) taken off the air intake tube (?) and shot it with starter fluid....it runs till the fluid is gone....could this be the ecm?....i don't want to take it to a shop if it is an easy fix....if not then i will have to bite the bullet and pay the bucks.....what do you think?
Old 09-30-2004, 10:27 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: electrical fuel problems
fuel pump is probably done.
Old 09-30-2004, 10:31 PM
nlghtcrawler nlghtcrawler is offline
Send a message via AIM to nlghtcrawler Send a message via MSN to nlghtcrawler Send a message via Yahoo to nlghtcrawler
ok, i have the exact same car, prty much, and ur problem sounds like mine, i havent had this problem cuz i repaced a 15 amp fuse, i dont know what it was too!, but i just replaced it, and it works great now, i would just check ur fuses! it MIGHT be the problem.
Old 09-30-2004, 11:20 PM
y2icon's Avatar
y2icon y2icon is offline
Send a message via AIM to y2icon Send a message via Yahoo to y2icon
check the fuel pump and fuel pressure to make sure your getting enough fuel
Nitrous= the car equivalent of a penis pump
Old 10-02-2004, 11:03 AM
NINÅ's Avatar
NINÅ NINÅ is offline
Connect a wire to the fuel pump input near the tank. Connect a test light to the wire so you can see it when you drive. If the light goes off when driving the pump is GOOD therefore you then trace the intermittent back. If the light stays lit R&R the pump.
REFUSE TO LOSE
Old 10-02-2004, 11:09 AM
1992RS 1992RS is offline
Send a message via Yahoo to 1992RS
check your oil pressure switch. If it's faulty it will cause your fuel pump to shut off. check the connection on the relay and the pump, check for frayed and exposed wires.
Old 10-02-2004, 01:50 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
my first guess would be the fuel pump its self, but what it sounds like is an intermittant electrical connection, such as the oil pressure switch as 92RS said, or it could be a bad fuel pump relay, or anything like that, check the ciruit for any signs of damage, corrosion, or burning.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 10-02-2004, 10:13 PM
Thanks for all the input. I took it to the dealer and they think it is the ECM. they wanted $350.00 to do the job. I have connections and a new ECM is $75.00. I hope that will fix it. will keep you posted!
Old 10-13-2004, 05:31 AM
Bravetex Bravetex is offline
I'm interested to know what you have finally done to solve this problem?
Old 10-13-2004, 09:10 AM
so far the ECM didnot fix the problem. we are now in the process of checking the wiring from the relay to the fuel pump....it sat for 5 days and did not start. we raised the rearend to check the wiring and it then would start.....loose wires/connections?...hmmmmmm!
Old 10-16-2004, 06:38 PM
camero_chic_1985 camero_chic_1985 is offline
my 87 did that also. i had to take it out and buy a new one so u may have to do that to...
Old 10-16-2004, 07:46 PM
89IROC&RS's Avatar
well well well, might i say welcome to all the noobs, glad to have ya on board.
Old 11-07-2004, 11:52 AM
WELL HELL......after all that guessing and trying this and that....it was the fuel pump.....the mechanic had never seen an intermintent fuel pump like that one....THANKS FOR EVERYONES HELP!
Old 11-07-2004, 02:18 PM
Genopsyde's Avatar
The President
that's right.
