Old 09-30-2004, 09:22 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
Angry whats wrong!?!
alright, i have a weird ass problem here now, if i have the car idleing and i hit the brakes hard once or twice then hit the gas, it shoots tons of smoke out of the exhaust, and its white smoke too, but its not burning coolant because i only have water in the cooling system at the moment so i can get everything flushed out. but yea, whats wrong with it? is it hooked up to the wrong vaccum spot? is the valve broken? and is the booster shot?? anyone know?? and it did the same thing with my stock d15b2
Old 09-30-2004, 09:28 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
only happens after you hit the brakes?
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 09-30-2004, 09:31 PM
1PhatCX's Avatar
yea if i hit them hard, like if i had to do it in a panic then it would smoke and bog a bit
Old 09-30-2004, 09:46 PM
CRXsiZCpa's Avatar
CRXsiZCpa CRXsiZCpa is offline
Re: whats wrong!?!
I know that you have to put the brake booster line on a different spot for the PG7 Intake Manifold. Check the vaccum lines. Sounds like one might be mixed up. Also check for vaccum leaks.
Old 09-30-2004, 11:54 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
Re: whats wrong!?!
master cylinder is leaking into your brake booster, and your engine is sucking it in through the booster vacuum line
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 10-01-2004, 10:27 AM
1PhatCX's Avatar
Re: Re: whats wrong!?!
are you fucking kidding me? that was a fuckin new master cylinder i put on like 8 months ago!!
is there any way to fix the leak?
Old 10-01-2004, 07:09 PM
EF You's Avatar
EF Life Giver
Re: whats wrong!?!
you can rebuild it, if you can find a rebuild kit. you have a warranty for the master cylinder dont you?
also, a lot of places wont warranty a booster unless you change the master cylinder too.
Old 10-01-2004, 09:12 PM
1PhatCX's Avatar
is it hard to rebuild the booster?? and i think the master is still under warranty, it should be
Old 10-02-2004, 08:53 AM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Re: whats wrong!?!
Are you losing brake fluid?
Old 10-02-2004, 12:59 PM
1PhatCX's Avatar
yes... yes i am
i thought it was from my caliper tho cuz the boot has a little tear in it
Old 10-02-2004, 03:21 PM
johnb16a2's Avatar
Re: Re: Re: whats wrong!?!
Originally Posted by 1PhatCX
yes... yes i am
The caliper boot is just a dust shield, the piston ring does all the sealing (which sounds like you need to rebuild or replace as well).
Your problem is most likely the master cylinder.
BTW, the booster is rebuildable but it's easier (and probably cheaper) to replace it with a reman unit with a warranty. Which, I think, you need to replace now that it's been contaminated with brake fluid. Verifcation anyone?
Old 10-02-2004, 05:45 PM
EF You's Avatar
EF Life Giver
Re: whats wrong!?!
yeah, if brake fluid leaked out of the master cylinder, and got sucked into your intake manifold, its safe to say that your booster is ruined
Old 10-02-2004, 05:55 PM
1PhatCX's Avatar
thanx for the help guys
also, will one off a 91 teg work for my car? booster and master?
Old 10-02-2004, 06:43 PM
EF You's Avatar
EF Life Giver
Re: whats wrong!?!
yes
Old 10-03-2004, 12:30 PM
1PhatCX's Avatar
sweet!
and i dont hafta mod it for sure? just bolt in
