Go Back   Automotive Forums Car Chat > Cars in General > Exterior | Bodykits | Lighting | Aerodynamics
Exterior | Bodykits | Lighting | Aerodynamics Discuss different body kits, body work in general, and all types of exterior modifications.
Old 09-30-2004, 08:37 PM
grim0404 grim0404 is offline
metal sanding
i have a 1967 mustang i started to sand down the mustang to bare metal i got 90% done then i cleaned it with a degreser then primered it very heavy amonth later it started to rust what do i need todo??or what is the process to paintin from bare metal and where can i find it??
Old 09-30-2004, 10:19 PM
Geeko Geeko is offline
Send a message via ICQ to Geeko
Did you use any cleaner or sanding between the degreaser and the primer? also, how many layers of primer did you put on, and how thick were they? in general, you want thin layers of paint, with some sanding in between to help it stick.
I could be wrong, though, I havn't painted many entire cars.
BD (Before Deer): Clean... Very Clean.
AD (After Deer): Nascar Ready.
Go Baby Go.
Old 10-01-2004, 08:09 PM
Re: metal sanding
after degresing it i didnt sand it i cleaned the degreser with a dry rag then i proceeded to primer then a month later im getting rust i regret sanding it
Old 04-27-2005, 10:28 AM
jveik jveik is offline
Re: metal sanding
yeah you maybe had a film of crap on there from when u degreased it that wouldnt allow the primer to stick very well. also, ive heard from some people that primer lets water through it so if it was wet a long time maybe it let water in because it didnt have normal paint on top to keep the water out.
Old 04-27-2005, 11:07 AM
astroracer's Avatar
astroracer astroracer is offline
What kind of primer was it? Probably a SS primer/surfacer. It will let moisture through and the steel underneath will rust. You'll have to sand it all off to make sure all of the rust is gone. Next time shoot it with a 2 part Epoxy primer to seal it then spray the primer/surfacer over that to finish your body work and blocking...
Mark
