Old 09-30-2004, 07:52 PM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
piston damage?
last night i i pulled the hed off my 90 TSi and saw first hand the bent intake valves. i couldn't pull the entire head off by myself cause the car is in awkward positions, but i did lift it and flashed my light in there and looked at the #1 piston. i noticed the 2 gouges where the valves made contact. now do these gouges mean that i will have to replace all the pistons? i would assume there might be hairline cracks in them from the valve-piston contact. any ideas?
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
Old 09-30-2004, 08:03 PM
1g90gsx's Avatar
1g90gsx 1g90gsx is offline
small indents from the valves will be just fine,deep gouges on the other hand is a different story.but if theres just nicks then theres nothing to worry about.
1990 MIRAGE HB
4G SWAP
FMIC
ACT 2100
TIAL BOV
TIAL WASTEGATE
FIC 650"s
SX AFR
MAFT
INNOVATIVE DUEL BB TURBO
TURBONETICS MANIFOLD
255 PUMP
WISECO 8:51
EAGLE RODS
DELTA 272 CAMS
SETRAB OIL COOLER
AEROMOTIVE STARLITE HOSE
AUTOMETER
ROTA CIRCUT 8"S
Old 09-30-2004, 08:12 PM
Testiklees
Re: piston damage?
i dont really know what to classify them as, gouges or just small indents....i'll have to take another look at them real quick.
Tim
1990 Talon AWD
PTE SCM5031
Old 09-30-2004, 08:35 PM
1g90gsx's Avatar
put up a pic if you can.
1990 MIRAGE HB
4G SWAP
FMIC
ACT 2100
TIAL BOV
TIAL WASTEGATE
FIC 650"s
SX AFR
MAFT
255 PUMP
WISECO 8:51
EAGLE RODS
DELTA 272 CAMS
SETRAB OIL COOLER
AUTOMETER
ROTA CIRCUT 8"S
Old 09-30-2004, 08:41 PM
Testiklees
Re: piston damage?
id like to, but no camera
my camera is in california right now, and im in NY!!
Tim
1990 Talon AWD
PTE SCM5031
Old 09-30-2004, 10:44 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Re: piston damage?
they should be fine... i went thru 3 heads bending pretty much all of the valves each time and my pistons are still fine! i wouldnt be that worried if i were you. once you get the head all the way off make sure that the pistons are still intacked and turn the motor over by hand to make sure everything is working correctly! clean out the cylinder walls really well and be sure to get everything out of the cylinders before you put the head back on!
Old 09-30-2004, 10:59 PM
Testiklees
Re: piston damage?
excellent! now all i gotta do is figure out where all these lines go back to.....
Tim
1990 Talon AWD
PTE SCM5031
Old 10-01-2004, 04:56 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: piston damage?
Dont foget that there are already "indents" in the pistons stock, called valve reliefs. Even in the pics of my bad pistons, you can still see them.
http://www.posracing.net/AFR.html
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
