Old 09-30-2004, 07:06 PM
3GT96 3GT96 is offline
different 16g versions
hi,
I'm looking around to try and find a trubo that will work with a 1999 GSX. After some research, I narrowed my search down to a 16g. I want to keep my car a daily driver, becasue I'm only going to use it for street anyway, but I want to get some nice horsepower out of it as well. Also, having a turbo with a fast spool would be nice. I know that the spooling time on a 16G is around 3000-3500 RPM, but there are alot of versions of the 16g like the evo and the BIG16g. What would be a good version of the 16g that would be closest to what Im looking for? If you can help, can you tell me what kind of horsepower I would achive from it? Also, where I can find one and DIFFENTLY how the spool is. Thanks for the help
Old 09-30-2004, 08:29 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
Re: different 16g versions
EVO Big 16g...
flows almost as much as a 20g with less lag. very streetable and a killer at the track with the right support and mods. with a GSX and the right driver high 11's are not unthinkable
Old 10-01-2004, 05:07 AM
kjewer1 kjewer1 is offline
AF - Advisor
Yeah, with the minumal price difference, there is no reason to not got EVO3 16g. SBR was selling them for like 560 shipped a while back. Thats peanuts for a turbo. I think it will fit your goals nicely, if a decent street car is what you are after.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 10-02-2004, 02:33 PM
about how much longer is spooling time on the the EVO 16g than on the stock?
Old 10-02-2004, 02:56 PM
about how much horsepower will I get with changing to an EVo3 16g? where is a good place to get everything I need to install a evo3 16g?
Old 10-02-2004, 04:57 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
~3300-3500 rpm. You could get a lot of different numbers, and it really doesn't matter. 300whp to 350whp is my guess. Track times is where a turbo is measured. Anywhere from high 12's to high 11's.
Road Race Engineering sells the install kit for a 16g turbo, and I think Slowboy racing has the cheapest EVO3 16g's right now at around 569.
Old 10-02-2004, 06:50 PM
joemathews's Avatar
joemathews joemathews is offline
You will do things right and ensure you have all the necessary parts if you buy a complete install kit for a 14b/16g from a vendor. These are really expensive, though. You can piece together the "kit" you need from oil feed and return lines from other 16gs or 14bs, along with a 1g J pipe that you can pick up on ebay. It should be easy to get all of the gaskets, lines, and the J-pipe you need for under $100...most vendors charge $200+.
1996 Eagle Talon
Old 10-02-2004, 11:40 PM
thanks
Old 10-03-2004, 11:30 AM
how much PSI of boost can I run safely with the evo3 16g on stock parts?
Old 10-03-2004, 11:58 AM
scottsee scottsee is offline
Send a message via AIM to scottsee
not sure. i've see 20-24
DSM geek
Old 10-03-2004, 04:11 PM
JoeWagon's Avatar
Banned
The EVO3 16g won't break much, maybe blow a headgasket. If you had a better gasket and maybe ARP head studs, I don't see the turbo making enough power to break anything, at any boost. What boost you'll run is dependent on if you knock or not. It will probably be around 19psi on the street and the fastest evo 3 16g's push 28 or 29psi.
Old 10-03-2004, 07:06 PM
So I can run 19 PSI safetly on pump gas with no other mods?
Old 10-04-2004, 03:19 AM
AF - Advisor
Nope. You'll need fuel upgrades, tuning/logging devices, and good intercooling.
Kevin Jewer
Old 10-04-2004, 10:06 AM
joemathews's Avatar
Re: Re: different 16g versions
Get out the wallet!
1996 Eagle Talon
Old 10-04-2004, 04:30 PM
What psi can I run without having to screw around with a fuel controller?
