Old 09-30-2004, 06:12 PM
mitchdakid mitchdakid is offline
1996 Keyless entry
I have looked at some of the other keyless entry threads but still cannot figure out how to get my remote programmed to my blazer. Can anyone help me with detailed instructions on what to do.
Old 09-30-2004, 11:04 PM
Todd6590 Todd6590 is offline
If it's like my 95, here's how I did mine:
On the driver's side, under the dash there is a panel that is removed with 4 screws, Attached to this panel is the keyless remote console. There should be 2 plugs plugged in to this console (they are on the side facing the firewall). Attached to one of these plugs is a red wire with a plug attached. Get another wire and short out the plug (basically, there are 2 metal tabs - get a wire to touch both tabs together). When you touch both tabs, the electric door will lock (or unlock). Now with plug shorted out, press any button on your remote. Remove the wire you used to short the plug and you are finished. Good luck
Old 10-01-2004, 03:56 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 1996 Keyless entry
Nice guide, I will keep that in mind for my 1995.
Old 10-01-2004, 05:08 PM
earp earp is offline
good guide, it does apply to a chevy balzer 2000?
Old 10-02-2004, 01:48 PM
BlazerLT's Avatar
AF -Advisor
Who knows, he stated that he used it on his 1995.
Only way is to try, but I wouldn't though.
Get the dealer to program it for cheap. That way you don't blow something electrical because your lack of knowing how to do it properly.
If you don't know, DON'T GO!
