1992 S 10 runs like crap !!!
Hello My 92 S 10 2.8 Idles Rough And Studders Down The Road.i Replaced These Sensors: The Temp,map,tps,ign Module. Cleaned:egr,iac,t-body.tune Up
lugs,wires,cap,rotor,air & Fuel Filters,checked Cat Ok,and A New Fuel Relayreplaced. I`m Stumped To No End On This Please Help.the Truck Had Codes 22,33.cleared Them And Still It Runs Like Crap.
Re: 1992 S 10 runs like crap !!!
ummmm....
2.8L in a 1992? |
yes a 2.8 v6 with a standard tranny
ok no codes, but still idles bad any info. please what to do next?
Time to set the timing properly.
Remember to disconnect the timing wire comign from the ECM under the carpet below the glove box. It should be brown and beige colored. Disconnect the wire, time the vehicle to O TDC, reconnect the wire, remove the negative battery cable from the battery for 5 minutes to reset the computer and you should be good to go. |
BlazerLT why the timing?
Because, timing is crucial for your vehicle.
Over time is goes out of adjustment. |
Re: Re: 1992 S 10 runs like crap !!!
it was the fuel regulator in the gas tank all fix and runs great thanks to all |
Re: Re: Re: 1992 S 10 runs like crap !!!
having the same problem adjusted the timing runs different but not to performance. how did you find out about the fuel regulator and test it.
Did you remove the timing wire when you were setting the timing with a timing gun?
Were you actually using a timing gun? |
