Old 09-30-2004, 02:43 PM
Expando1 Expando1 is offline
Question Idle Control?
Where is the idle adjust on a 1990 Civic LX? I look underhood and see something that looks like a cap with a spring underneath and a depressed hole in the middle of the cap. But there is not screw persay where I can fit a phillips' or flathead screwdriver to adjust the idle. Any ideas? or a pic perhaps?
Old 09-30-2004, 07:05 PM
1990civicdxhb's Avatar
1990civicdxhb 1990civicdxhb is offline
Re: Idle Control?
its under that black ugly box on top of your throttle body,
it is near that spring,
if you cant see the screw,you probably have a cap over it,its a black small cap,pull it off & you'll see a gold screw!
In the process of B00stin my D
Old 10-01-2004, 12:14 AM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
Re: Idle Control?
if you cant find the screw maybe you shouldnt try to adjust it...haha
90 Honda CRX Si
-Red/Black
-B20B/b16
-AEM CAI -/\- Apexi GT Header/2¼" Custom Dynomax Exhaust
-Tein SS CoilOvers with pillow ball monuts -/\- ST Swaybars/Energy Suspension Bushings
-16x7 Lightweight Rotas -/\- Pro Stop Rotors -/\- Goodridge S.S. Brake Lines
-Skunk2 Shifter -/\- MoMo Steering Wheel
Old 10-01-2004, 08:51 AM
91civicDXdude's Avatar
Re: Idle Control?
you shouldn't need to adjust idle. If the idle isnt proper, you probably have a vaccum leak, your timing is off, or the engine has some other problem. the only reason you should need to ever adjust idle is if somebody already adjusted it improperly. there is a screw on the throttle body.
Old 10-08-2004, 02:03 AM
EF_CaSe EF_CaSe is offline
Send a message via AIM to EF_CaSe Send a message via Yahoo to EF_CaSe
Talking Re: Idle Control?
if u took the motor out for some reason or took the throttle cable off u should check the to nuts on the cable that u thighin together to hold the cable in the bracket.. thats how i adjust my idle... jus have some1 sit in the car n loosen them 2 screws n set it at what u want... how do u add pics??
[]D [] []V[] []D ........ []D [] []V[] []D
