Old 09-30-2004, 02:38 PM
bigal0043 bigal0043 is offline
How loud would this system be??
hi im on a little budget and was looking at this combo of a lanzar amp and dual 12's... i already have a pioneer cd-player.... i was wondering how good would the combo be??? would it be very loud ??? im kinda lookin for a amp and sub for under 250 if anyone has any other suggestions....would the Lanzar VIBE241 1000 Watt 2 Channel MOSFET Amplifier be better than the heritage?? if i were to get this would it be better to have the subs bridged or just use the indvidual channels??
Thanks for any help
Alex
The sub:
Two 12" High Power 4 Ohm Subwoofer
Silver P.P. Cone/New Pattern
Specially Treated Black Rubber Edge Suspension
2.5" Kapton Voice Coil
White Neon Light Silhouette
High Quality Construction
Quick Connect Terminal
Plexi Glass Window
Four Aluminum Port Tubes
1200 Watts Max Power Handling
Dimensions: 38"W x 16.4"H x 13.6"D
the amp is a Lanzar HTG244 2 Channel 1000 Watts High Power MOSFET Amplifier
2x250W RMS at 4 OHMS. 2x500W Max at 4 OHMS
1x1000W Max at 4 OHMS Bridged. 2x420W RMS at 2 OHMS
MOSFET Switches to Maintain Rated Power Over A Wide Range of Battery Voltages
Stiffly Regulated PWM-Type Power Supplies
2 Ohm Stereo Stable Operation
Stereo, Bridge and Tri-Mode System Application Compatible
Variable Input Level Controls For Each Pair of Channels
Variable High and Low Pass Crossover Controls
Thermal and Speaker Short Protection Circuitry
Power and Protection LED Indicators
Bass Boost Circuitry
Nickel Plated Power, RCA and Speaker Connectors
High-Efficiency, Heavy Aluminum Heatsink
Bass Boost Remote Control
Bridgeable at 4 Ohms
THD: <0.04%. S/N Ratio: >90dB
Channel Separation: >65dB
Freq. Response: 10Hz~35KHz, 1dB
Fuse: 20A x 2
Dimensions: 9.82"(W) x 2.34"(H) x 13.46"(L)
2 x 200 Watts RMS at 4 Ohms
2 x 500 Watts Max at 4 Ohms
1 x 800 Watts Max at 4 Ohms Bridged
2 x 375 Watts at 2 Ohms
MOSFET Switches Maintain Rated Power Over A Wide Range of Battery Voltages
Variable Input Level Controls for Each Pair of Cannels
Variable High & Low Pass Crossover Controls
Remote Subwoofer Bass Control
Electronic Crossover Network
Bass Boost Circuit
2 Ohm Stereo Stable
Tri-Mode Capable
Gold RCA Inputs
Line Outs for Left & Right Channels
Power & Protection LED Indicators
Advanced Protection Circuitry
Soft Turn On/Off
Frequency Response: 15 Hz-35 kHz
S/N Ratio: 90 dB
Dimensions: 10.25"W x 2"H x 15"L
Old 09-30-2004, 02:45 PM
FYI i drive a chevy s-10 blazer 2-door... didnt know if that makes a diffrence in sound quality.... a quick question how loud does it take to break a window??
Alex
Old 09-30-2004, 03:20 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: How loud would this system be??
the subs are crap, I can tell because there's no brand name, they're rated in max power, they come housed in a bandpass box, and there are absolutely no usefull specs, the entire description just talks about useless cosmetics. So the subs are out, and the amps aren't much better. The only Lanzar worth mentioning is the Opti series, all the other ones aren't worth the scrap metal they're made out of.
Amp and sub under $250? That won't get you very far, maybe a shiva in a custom ported box on a profile california, but once you add in supplies for the box that'll put you over budget. You really can't get anything quality in that price range, and I don't mean "quality" as in "the best there is", I mean "quality" like "won't kick the bucket after 5 minutes of play".
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 09-30-2004, 04:20 PM
thanks for the reply.. do u have a link for those shiva things u mentioned?? im really not looking for a real loud bass just something that sounds good...and sometimes to turn some heads my way
Old 09-30-2004, 06:12 PM
sr20de4evr's Avatar
http://www.adireaudio.com/Files/cut%...20Brochure.pdf
http://www.acoustic-visions.com/~aco...rs/adire_shiva
'01 Black Sentra SE
'05 Silver WRX STi
Old 09-30-2004, 06:57 PM
those fu*kers are expensive. for one it is like 130 bucks..got any other suggestions little cheaper
Old 09-30-2004, 07:28 PM
loismustdie loismustdie is offline
that isn't expensive at all when it comes to car audio, but for cheaper, maybe a kicker comp vr, can be had pretty cheap on ebay. not bad sq, best for the money probly.
the aquabats are seriously the best band in the world
Old 09-30-2004, 07:36 PM
sr20de4evr's Avatar
$125 shipped is expensive?
that's news to me....
'01 Black Sentra SE
'05 Silver WRX STi
Old 09-30-2004, 07:41 PM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
DO you listen to sh*t for car audio? COME ON MAN. Have you been in any car audio store? that is cheap as crap for one sub... If you don't give a rip about how something sounds loud or quality and just want bass get something cheap...
I looked on ebay at the crap woofers that still get loud... 150 for 2 that only do 300 watts a piece at MOST...
www.cloudcity.deviantart.com
Old 10-05-2004, 11:05 AM
okay then so they are 125 shipped for one right?? that dosent include a box right... does anyone have any plans for a box that i could make myself?? also what would be a good amp to run those subs?? thanks for the help guys i dont mean to be so cheap.
Old 10-05-2004, 11:09 AM
okay then so they are 125 shipped for one right ... i do have alot of money i could spend i was just throughin out a number to try to stay around...if i got one sub now and another one later would that be very loud with just one???? that dosent include a box right... does anyone have any plans for a box that i could make myself?? also what would be a good amp to run those subs u said a profile cal should i get a 2 channel one or a mon channel one?? thanks for the help guys i dont mean to be so cheap.
Old 10-05-2004, 11:33 AM
sry for double post
Old 10-05-2004, 12:07 PM
so i was looking at the profile ap1200 would that be a good amp to go along with 1 or 2 shivas??
http://www.profileusa.com/products_amps_ap.cfm
or would a profile clarus CL800 be better??
http://www.profileusa.com/products_amps_cl.cfm
another quick question with those shivas would it be running at 2 ohms all the time??thats better right??
thanks guys
Old 10-05-2004, 01:03 PM
sry for all these posts but i got alot of time on my hands today.... but i was reading that a profile ca-600 with a tempest would be good... would it??
Old 10-05-2004, 03:30 PM
Haibane's Avatar
go AP before clarius, see if you can find some CA amps..
